Forward Collision Warning (FCW) - option missing
mcat79
A while back I disabled FCW on my 2022 Laramie, and I was looking to reenable it. It appears that the option to enable/disable is no longer there. Can anyone else confirm in the most recent update (FCA-MY24.U35.26-PROD) if their setting is there or if it looks like mine? See attached
Same issue here. The option disappeared after that update. Now I get "auto brake disabled" in the messages with no way to turn it on.
I have never been able to completely turn mine off, are you saying there was an actual On/Off selection for you?
Yeah, there was an option. Here is a screenshot I found online.
I believe that in 2023 it became a requirement and can't be turned off. Perhaps that's what is going on now. They removed the option to turn it on and off now.
Bought my '22 in April of that year, there was not an option on mine. I wonder if it has something to do with mine being a Level B as opposed to a "2" or "II".
And I definitely didn;t have that many nanny choices, which is one of the reasons I bought the truck that I did.
My 24 had the option to turn it off/warning only, then that stupid update hit and it disappeared. Since I had it set to warn only, the messages center always shows "auto emergency braking disabled".
I have yet to have my front collision braking come on on my 2025. I've gotten the audible warning a couple times but I am not really sure if the collision braking is even working.
Anyone aware of an alfaobd option to enable/disable FCW?
Check the PDF for all the settings.
