2025 speaker issues-driver side distortion
RossG123
Anyone with a 2025 Tungsten having an issue with drivers side speaker distortion?
Specifically the bass 6x9 speaker at the bottom of the door.
It sounds like its blown (rattle/crackle sound) and I had the dealer replace the speaker and the same problem remains.
I have tested this by isolating the sound through the 4 corners fader/balancer in the speakers menu option.
What's odd is the day before in one instant all 4 speakers sounded blown through my isolation testing and today its back to only the lower drivers side.
It doesn't matter the source of music...radio, carplay ect...
I also seem to get a bit of distortion when at idle with from that speaker at idle with no music playing.
probably the amplifier
Dealer says another car in their shop has the same issue and it came like this from the manufacturer. Doesn't seem like this is going to get resolved.
My Tungsten has been at the dealer for 5 days now because of the woofers in all 4 doors are making a rattling noise at volumes above 25. I really think it is the felt behind the speaker grill making the noise and not the speaker. Will let you know what they come up with.
Went to pick up my truck on the 3rd because the service advisor said they didn't have a fix. He told me this without even taking off the door panels. Terrible. Got to the service department and I lucked out as the district service manager was there and I asked to talk to him. He came out and heard what was going on and immediately ordered 4 new door woofers. I am hoping they find a solution.
I installed new Infinity speakers in all of my '25 Laramie doors and I still have what appears to be the same distortion/vibration in the left front door. So you may not be any better off with new factory components installed.
My distortion is not constant and for the most part barely noticeable, but possibly suggestible that the speaker itself for that door just needs a decent layer of foam insulator between its mounting base and interior door frame.
If it's a front-facing issue between speaker and door panel, maybe some dynamat or other stick-on insulation onto the interior panel wall may be another solution.
These will be my next moves whenever I get motivated to pull the panel again.
Was it difficult to remove the door panels and did you do all 4 doors?
I am pretty sure them replacing the speakers will not solve the issue and will probably end up finding a solution myself. If I pull the doors, I will definitely be putting some sound deadening in place.
You could try replacing the fuse that powers the audio. And or the amp. Or check the amp for tight connections.
It's not an audio signal issue, it is a speaker hitting something or something rattling in the door in heavy bass situations.
Door panels removal is an easy 5-minute job. There are bolts inside a small cover in the middle area behind the interior door handle that need to come off first and the outer panel perimeters are all held in by push-pins. So once the bolts are removed you just pull on the outer edges of each panel and it comes off.
The covers hiding the middle area bolts come off easily, you just push a small flat blade screwdriver into the little recess opening and pry the cover out.
Have a Tungsten experiencing the same issue. Did you ever determine what the solution was? It’s the only speaker doing it and it’s extremely annoying.
I just got my truck back from the dealership after they replaced all 4 doors 6x9's and the rattle is still there. I have been in communication with Stellantis Customer Care the whole time and have also reached out to Klipsch asking if they could help. Ram has not offered a resolution yet but did receive an email from Klipsch today acknowledging that there is and issue and it is with the door panels and not their speakers. See below message. I have suggested to the dealership that they have a local audio shop diagnose the rattle and offer a resolution to it. Will see where this goes.
Eric Bedwell (Klipsch Product Support)
Jul 25, 2025, 10:05 AM EDT
Hi Shawn. I reached out to our internal team and apparently they are already aware of this problem you are having with your truck speakers. We have been in contact with Panasonic Automotive and what we have determined is that the issue is with the door panel and not the drivers. Unfortunately, this is something the dealer would have to take care of.
I apologize on that, and if you have any other questions regarding Klipsch in the future, please let us know.
Thank you and have a great weekend!
My truck is back at the dealership having all 4 door panels replaced this time. Let's see what this does.
They did put me in a brand new 2500 diesel while they are working on mine.
Interesting that this should get refreshed at this time. My 2025 Tungsten started having the exact same symptoms about a month ago. I took it in and they replaced the speaker saying it was blown. Pick it up and it still had the same sound. The technician came out and said he replaced the small speaker near the window, not the one in the door panel because he heard a hissing from it(I assume the hissing is from the ANR system). Have an appointment next week to get the correct speaker changed out. Wil follow up as it apparently may not be the speaker after reading this thread.
At least they did change the steering wheel during that visit as it had delamination on the top of it. Something to keep an eye on, as it appears to be dirt from resting your wrist on top of the steering wheel while driving, but it does not clean off. Use those warranties boys and girls!!
Same. Taking in tomorrow to dealership but suspect it is something other than speaker
Going on week 4 of being without my truck as the dealership and Ram can't seem to figure out the rattle. They should just get a local car audio shop to diagnose and add some sound deadening to the door and panel. Easy fix. We know it is not the speakers as they have replaced those already. This is the 3rd time it has been in the shop for this. Come on @RamCares , step up your game and seek outside help. If I have to take it back again (when they give it back to me), I'm contacting a Lemon Law Attorney.
Man this is driving me crazy! Im glad to see its not just me though. Its my rear drinker side that is rattling with any type of bass, and it does seem to be getting worse. Its now rattling on front as well. Im gonna pull the door card and see what happens without it on, maybe head to a car stereo shop and get some dynamat.
Super frustrating...
I just got my truck back from the dealership today with no fix. I also plan on pulling the door panels and isolating the noise. Let me know what you find when you pull the door panel and run test. I'll do the same.
I’m beginning to think assemblers are purposely ****ing these trucks up.
