2025 RAM trailer camera
As I back up my enclosed trailer and look at my 2025 DRVM . . . and I note the button to view a trailer camera on said DRVM . . . but I remember it takes a specific camera because the mirror is proprietary . . . and then I realize that the truck has been out for 15 months but no such camera is available . . . I want to drink whiskey and kick my cat.
That is all.
That is all.
It’s criminal.
I agree.
Hello Guys, just traded in my 2002 Ram 2500 and am now the owner of a new 2025 Ram 2500 Big Horn equipped with trailer package. On my camera's screen I have options for an aux1 & 2 camera's. I am looking for advice on a single rear view camera to put on my Pre-wired 5th Wheel camper. Its mid July already, I have skimmed over all the comments and advice in this post and hoping to get a suggestion for a camera, and connection wiring to fit my needs. Any advice would be greatly aprritiated.
Dave
Dave
I think there are many of us waiting for the same info. I don't think it exists yet, but maybe I'm wrong.
Personally I'm waiting for @Jimmy07 to tell us he's personally tested something or has solid knowledge of a p/n that works.
Dave
You should really join HDRAMS.COM
Clarification:
DRVM = Digital Tow Mode camera shows on DRVM - plugs into funky new "coax"
360* or AUX/AUX2 trailer camera = shows on UC screen Aux1/Aux2 - plugs into 12-pin receptacle (assuming this is present) and if you have blue screens on AUX1/AUX2.
Visionworks sells a wireless kit that plugs into the 12-pin. Camera quality should be much better than (analog) OEM (which are crap).
Keep in mind, the UC display times out at 8MPH or 8 seconds if moving forward. These are good for backing, but without a Tazer or Naviks (black box), they're not good full time observation cameras.
I'm still absolutely perplexed how we could be nearly 18 months in to this platform and not have a DRVM camera option when the mirror was clearly designed for it. Every time I look up at my DRVM and see only the front of my enclosed trailer, I want to lash out irrationally.
It's a shame I had to, but I ended up buying the below to get me the visibility I need until the Ram trailer camera compatible with the DRVM is released (if ever).
It's actually a lot of tech for the money, and it works well. The mount linked below is a good one also. I just don't really care for having an additional monitor in the truck along with the DRVM, dash cam, and U-connect screen; it looks like a damn command post. Hopefully, it's only temporary.
Hi, Just put a deposit down on a 25 Rebel with all the tow packages. Does anyone know if there is an update on this? Thanks!
No, But I'd ask your dealer, see what they say..
i have a 2024 ram 3500 unlimited and got the rear view mirror where you can connect a trailer camera and see in the rear view mirror. been trying to get this camera since last year that i purchased the truck and was unable to get, did not show a part number or even a kit for this truck. Went to dealer today where i purchase and sales person pulled a kit out on one of his 2025 that he had on lot. we tried it out in my truck and it worked perfectly. been trying to get this kit for almost a year
here is part number #68586112AA
Yep - that should work perfectly for your truck. That fits 2023-2024 HD trucks (with specific sales codes). It won't work on 2025 1500s.
I don't think it will work on 2025/2026 HD's either, they changed the connector.. possibly the CVPM and DRVM?
Bringing this to the top. Anyone had any luck with a trailer camera for the 2025 DRVM? We are approaching two damn years since the truck first hit lots . . .
Any chance someone has the part number for this version pictured? Working on a conversion to change over the rear bumper setup to a 25+ and cannot find any info on this connector. Thinking maybe it is 68578768AA but nothing out there I can find to confirm. I have the factory trailer surround on a 22 1500 that came with the 12/7 box mounted under the bumper so I want to clean it all up. I believe the body side/backside of this 12pin bottom port on the 25+ is the same as the 19-24 at least from the dozens of pics I examined on the web. I am willing to test it out but have to find this part first.
Parts to complete a conversion (3 total):
1> Dual camera 12/1 connector: p # ?????
2> Step pad for 12/1 on left and 7/4 on right: part # 68668549AA or 68668550AA (have not found real pics so all stock photos show with rear fog light cutouts) still trying to confirm that, 68668551AA and 68668552AA are 100% not for the trailer cams only has 12/4 on right. Only 4 different step pad versions for the 25-26 1500's.
3> Bumper center support bracket: part # 68566341AB (this is the main frame everything bolts to so is hidden from the outside, only needed if you desire to have everything correct for the retaining spring clips on the connectors when pushing into position and locking in place).
Note: This is based off already having all the wiring.
  • Members online
