Trailer Brake Control
Brahmajoe
Does anybody have any suggestions for a trailer brake controller? 2025 ram 1500 3.0 S.O
I’ve seen a curt wireless setup that looks convenient. Any help would be appreciated
The kit is available, comes with the switch, controller and wiring (which I did not use/need). My current issue is there was no cover plate for the remaining space. My dealer is working on finding the correct filler plate. This is on my 2025 Rebel X with the 14.5 inch screen.
Was this just plug and play or dealer needs to program?
Had to install the switch in the dash (connection was there) swap out the trailer control module behind the rear seat (existing on is lights only, new one is lights on brake control) The switch does not have the (+) and (-) gain on it, it shows on the display screen just above switch. So yeah, dealer needs to program it. Also, you odometer will will flash unit the dealer programs the truck for the new controller.. I guess this happens when any control module is installed and not programmed. Again, this is for the 14.4 inch screen. I would assume the procedure is the same for the 12 inch. The switch is different as it has the gain buttons physically on the switch versus on the screen
Did you ever find out what the part number is for the cover plate for the remaining space? I am in the same situation and cannot find the part.
I thought I updated the post, but apparently I did not. I don't have that part number anymore.... It seems the dealer parts department looks up parts by VIN, and can only see the parts for that VIN, so I ended up searching various dealer's on-line inventory for a truck that had the same screen and with a brake controller. I provided that vin to the parts department and they were able to get it in. Hope that helps!
