Was this just plug and play or dealer needs to program?The kit is available, comes with the switch, controller and wiring (which I did not use/need). My current issue is there was no cover plate for the remaining space. My dealer is working on finding the correct filler plate. This is on my 2025 Rebel X with the 14.5 inch screen.
Had to install the switch in the dash (connection was there) swap out the trailer control module behind the rear seat (existing on is lights only, new one is lights on brake control) The switch does not have the (+) and (-) gain on it, it shows on the display screen just above switch. So yeah, dealer needs to program it. Also, you odometer will will flash unit the dealer programs the truck for the new controller.. I guess this happens when any control module is installed and not programmed. Again, this is for the 14.4 inch screen. I would assume the procedure is the same for the 12 inch. The switch is different as it has the gain buttons physically on the switch versus on the screenWas this just plug and play or dealer needs to program?
