RamTruckMan
Behind the mainI have not looked yet - but need to. Where is the second battery?
That’s a long sentence, manSo saturday my battery went dead also its my own fault left keys out for over 24 to close to truck and no you don't put charger or jumpers on little battery
when I hooked up to just the main battery it would not let me start it. I had to hook up a second jumper to the little battery before it would let me start it.Don’t you just need to jump the main?
could you unlock your truck using your fob? Mine was completely dead. Had to use the actual key to unlock the truck.So saturday my battery went dead also its my own fault left keys out for over 24 to close to truck and no you don't put charger or jumpers on little battery
He's well know for his long sentences.... or paragraphsThat’s a long sentence, man
I know. It’s just a kind reminderHe's well know for his long sentences.... or paragraphs
What is this thing you speak of??? What is keycould you unlock your truck using your fob? Mine was completely dead. Had to use the actual key to unlock the truck.
Volts where at 8... Takes a few minutes to jump i already know to let it sit. My cel came on code for low volts went away next day.could you unlock your truck using your fob? Mine was completely dead. Had to use the actual key to unlock the truck.
For the window, tip in this forum: lower as far as it goes. Bump down 5-7 times. When fully down, Press and hold down for 10 sec, then hold raise and when fully up, continue to hold for 10 sec.2025 Limited SST HO. 1100 miles. Traded in 2019 RAM Limited. Issues to date on new 2025: 1. Passenger window will not go down all the way. 2. Backup camera blue screen of death. 3. Key fob not recognized when in truck and pressing start button. 4. Key fob will not unlock truck. 5. Button on door handle will not unlock truck. 6. Driver side seat position memory quit working. 7. Sirius radio would not come on. 8. Blind spot indicators in BOTH mirrors came on while starting truck. Issues 1-7 were intermittent and currently working okay after Central hub RF module replaced. Issue 8 - one time occurrence (so far) MOPAR says known issue, solution not yet known - working on it. Had I read though this thread before my purchase, would not have bought the truck.
Having one bum module isn’t bad, especially if replacing it fixed most of the problems.2025 Limited SST HO. 1100 miles. Traded in 2019 RAM Limited. Issues to date on new 2025: 1. Passenger window will not go down all the way. 2. Backup camera blue screen of death. 3. Key fob not recognized when in truck and pressing start button. 4. Key fob will not unlock truck. 5. Button on door handle will not unlock truck. 6. Driver side seat position memory quit working. 7. Sirius radio would not come on. 8. Blind spot indicators in BOTH mirrors came on while starting truck. Issues 1-7 were intermittent and currently working okay after Central hub RF module replaced. Issue 8 - one time occurrence (so far) MOPAR says known issue, solution not yet known - working on it. Had I read though this thread before my purchase, would not have bought the truck. That's on me.
Try this unhook batteries for an hour both .Then hook them back up let truck sit for 10 mins . Go in truck put it acc wait2 3 mins let all the computers talk to each other .After starting make a profile do all settings even if they look the same tap on them all had a lot of same issues .Never had window problems tho.o keep fob far away when off so truck will go to sleep lol.2025 Limited SST HO. 1100 miles. Traded in 2019 RAM Limited. Issues to date on new 2025: 1. Passenger window will not go down all the way. 2. Backup camera blue screen of death. 3. Key fob not recognized when in truck and pressing start button. 4. Key fob will not unlock truck. 5. Button on door handle will not unlock truck. 6. Driver side seat position memory quit working. 7. Sirius radio would not come on. 8. Blind spot indicators in BOTH mirrors came on while starting truck. Issues 1-7 were intermittent and currently working okay after Central hub RF module replaced. Issue 8 - one time occurrence (so far) MOPAR says known issue, solution not yet known - working on it. Had I read though this thread before my purchase, would not have bought the truck. That's on me.
guess it depends on the model -- mine has adaptive cruise to the left and hands free assisted driving in the middle of the resume/cancel buttonDoes anyone else find it annoying that trucks with adaptive cruise control have a standard cruise control button ALSO right next to the adaptive button AND in the middle of the resume/cancel buttons??? I can’t wait for ALFAOBD and, hopefully, it will have a way to disable it.
It has fixed things but i hit my profile manually after i start the truck cause i find it will not always go to your profile setting automatically .Does this work for you long term? I ask because the ram I bought (which is currently at a dealer for multiple issues) has/had a lot of electrical flaws, sometimes things would work, sometimes they wouldn't (certain warning lights, uconnect, start/stop, random messages on the dash, android auto and bluetooth randomly disconnecting, cams sometimes work sometimes they don't, auto dimming headlights and warning sensors also intermittently work/ etc.) Some of the issues were resolved with the battery(s) disconnect that you mentioned, but unfortunately most of the issues that were corrected with the disconnect would come back a short time later, until another disconnect was done. The dealer is finding some of the same random intermittent issues and is struggling a bit to diagnose it all but when I told them about the battery disconnect trick they told me that disconnecting and reconnecting the batteries is typically not a permanent fix but rather a temporary bandaid type approach until the real problems are found and corrected. Whether this dealer is 100% correct about that I do not know, but it seemed to be in my case. Hopefully your issues are permanently resolved with a battery disconnect.
