rrf8888
- May 21, 2025
[ISSUE] 2022 Ram 1500 Rebel — EPS Jerking, Park Not Engaging, Full Blackout After ABS Recall (75B)
Hi everyone,
I’m posting this to see if any other Ram 1500 owners have experienced a similar issue — especially after getting the ABS Module Configuration Mismatch recall (Campaign 75B / NHTSA 24V-653) done.
It’s very concerning that this happened after a safety recall. I’d really appreciate hearing from anyone else who experienced this — or who has insight into the relationship between the ABS and EPS modules.
Thanks in advance,
Rob
Hi everyone,
Vehicle Info:
- Model: 2022 Ram 1500 Rebel
- Engine: 5.7L V8 HEMI MDS VVT (EZH)
- Purchased: May 2023
- Mileage: 11,698 KM
What Happened:
May 15, 2025
Had the ABS module recall (75B) performed at the dealer. Software updated as instructed.
May 17, 2025
Roughly 100 km after the recall:
- While turning at about 50 km/h, the steering wheel suddenly jerked violently left and right, nearly causing an accident.
- My two minor cousins in the back seat hit their heads together and on the window due to the force.
- Tried to shift into Park, but the gear knob spun freely — it wouldn’t engage.
- When I shut the engine off, the entire truck blacked out — no power, lights, or signs of life.
- Truck only restarted after I disconnected the negative terminal for 10 minutes.
No check engine lights or fault codes appeared before or after.
May 19–21, 2025
Brought the truck back to the dealer:
- No codes showed on scan.
- Dealer found steering angle sensor was off by 7°.
- EPS module load/temp was at 50%.
- After cleaning ABS connectors and rotating the wheel a few times, a new DTC appeared:
➤ C2210-00 – ECU Overtemperature (EPS)
Has anyone else had this happen?
- Sudden steering kick or jerk after the ABS update?
- Park not engaging?
- Total vehicle blackout and EPS overheating?
Thanks in advance,
Rob
