Rambox wiring to main harness
dforaker79
Troubleshooting a nagging annoyance on my drivers side Rambox. The unlock button has never worked. It was not the lid or actuator because I took the lid off and plugged it into the other side and it works. So, I started looking at the wiring and found the main connector below the Rambox completely full of dirt and corroded so bad, I cannot even disconnect it from the Rambox. I even found one of the wires burned, falling out of the connector, and the wire next to it has insulation missing. I already ordered a new jumper harness and replacement jumpers for the Rambox. My question is, the passenger side has a shield to protect these connectors, it seems I may be missing it on the drivers side. Can anyone with Ramboxes verify there is a shield there underneath where the Rambox connects?
Sorry, I don't have the answer to your question, I'm replacing my truck bed (non ram box) with a ram box bed and am struggling to identify the part numbers - I need the jumper wiring (and harness maybe?) so was wondering if you please share the part numbers you used?
I bought the left side jumper.
how did your bed swap go? Are the locks n lights working in your ramboxes?
Just did this, but haven't gotten to the wiring yet.
Thanks
I finally did it 4 weeks ago, fairly smooth, but some damage to some connectors from the previous owner when the bed was removed. I've also discovered my chassis wiring doesn't have the wires for the ram boxes, so I need to tap into the chassis connectors at the back and front of the truck - then it should work hopefully.
What was required to tap into the chassis connector? My 2020 1500 (bought used) had the bed swapped for a rambox bed but the wiring was never completed.
I replaced 2 harnesses to suit the ram boxes, but the main one heading back to the BCM didn't have the wires. I have got all the pieces for it but yet to make it.
I am just running a separate set of wires that will follow the main chassis one, and I have the pin connectors (male and female) so I can connect into where they should go. I can upload some photos once I've made it.
Can you share any links or sites that helped you know what and where to tap in to?
Thanks!
