Rambox wiring to main harness
dforaker79
Troubleshooting a nagging annoyance on my drivers side Rambox. The unlock button has never worked. It was not the lid or actuator because I took the lid off and plugged it into the other side and it works. So, I started looking at the wiring and found the main connector below the Rambox completely full of dirt and corroded so bad, I cannot even disconnect it from the Rambox. I even found one of the wires burned, falling out of the connector, and the wire next to it has insulation missing. I already ordered a new jumper harness and replacement jumpers for the Rambox. My question is, the passenger side has a shield to protect these connectors, it seems I may be missing it on the drivers side. Can anyone with Ramboxes verify there is a shield there underneath where the Rambox connects?
Sorry, I don't have the answer to your question, I'm replacing my truck bed (non ram box) with a ram box bed and am struggling to identify the part numbers - I need the jumper wiring (and harness maybe?) so was wondering if you please share the part numbers you used?
I bought the left side jumper.
how did your bed swap go? Are the locks n lights working in your ramboxes?
Just did this, but haven't gotten to the wiring yet.
Thanks
I finally did it 4 weeks ago, fairly smooth, but some damage to some connectors from the previous owner when the bed was removed. I've also discovered my chassis wiring doesn't have the wires for the ram boxes, so I need to tap into the chassis connectors at the back and front of the truck - then it should work hopefully.
What was required to tap into the chassis connector? My 2020 1500 (bought used) had the bed swapped for a rambox bed but the wiring was never completed.
I replaced 2 harnesses to suit the ram boxes, but the main one heading back to the BCM didn't have the wires. I have got all the pieces for it but yet to make it.
I am just running a separate set of wires that will follow the main chassis one, and I have the pin connectors (male and female) so I can connect into where they should go. I can upload some photos once I've made it.
Can you share any links or sites that helped you know what and where to tap in to?
Thanks!
Thanks!
This is a summary of what I'm doing to connect the Ram boxes to the central locking and power the lighting inside.
You can buy the replacement chassis wiring but it is way more cost effective DIY.
I believe there will be 6 new wires, with the lighting wire joined when returning to the front of the car (so 5 into XY400A) - e.g., 1 each coming out of XY670 and XY675, but joining together for 1 connection to XY400A .
I was hoping to run these all together in a new tube/conduit, and zip tie to the existing wiring.
XY675A - requires male connectors for the below:
XY670A - requires male connectors for the below:
XY400A - requires female connectors for the below:
Wiring diagrams:
Have you made the wire harness already? I’d like pictures as I’m working on the same thing now.
Haven't made it yet, hoping to finally get to it over the next 2 weeks. Will post up pics and parts etc. if you still need?
How did you go with this? Interested what you put together.
I've only just made the harness, some photos attached. Will apply the heat shrink before connecting and will add some protective tubing. Gonna wrap the whole lot with chassis/body tape to protect as well.
These connectors etc. look to be correct. I feel the waterproof plugs probably aren't but will do part of the job and I'll seal the back with something else.
Hopefully will get some time to connect it up before Christmas.
I'm in Australia and this was the best site for me (DigiKey) - aware there's a few other out there that I have used, but needed some tools etc. as well so shipping worked out better.
Just created this thread of my bed swap, may have some helpful info for some.
