2025 Ram 1500 Current Owners - Discussion, Feedback, and Problems
Yea that is the one I tried to order from an online vendor and they cancelled my order because they said it was on national back order. I have not tried again just yet.
Tons of the 2025 parts are on National backorder. The tariffs will only make it worse🤷🏻‍♂️
Yea I guess I shouldn't be surprised that even air filters are on back order.
See if its the same parts as wagoner. Take it out just go to in store and compare there has to be same size air filter somewhere.Same crap was said in august 2024 for oil filter and just looked up wagoner oil filter ended up be same one.
I just popped the hood, the coolant and the little coolant tank for the turbos are below min. level.
Taking her in next Monday for a few nuances --
Still have a question: what is the OEM air filter # for the 3-liter SO?
Google search - even at many Mopar sites does not return any P#s for the air filter.
When its hot look at it.If you still see some in there when its cold your safe few ounces low.
@azzx
Ditto. I think it’s fine. My truck is going in next week, I’ll make sure they check fluid levels.
For both my two 2025s, they came with the coolant at the MIN line. But, I'm not a great example, as the first one continues to have coolant loss, and the second one was leaking at the water pump (fixed).
I recommend you guys wait until it is dead cold and on level ground, then fill it EXACTLY to the MAX line . . . much easier to monitor like that. Every couple days, check it when parked at the same spot, when cold, and with relatively the same ambient. If after a few weeks, there is no movement, you can have confidence all is well. This is what I did with the second truck after the water pump replacement.
Mine changed color, when I first got the truck it was like a dark purple after a few weeks I noticed it was more pinkish like rusty brownish kinda weird then a day later it was purple again. And mine is also right below the min line . Guess I need to check in when it's cold like first thing in the morning in level ground to make sure!
I agree engine coolant became way darker than the turbo coolant tank for sure.
The pinkish/brown look is normal . . . you also notice that it tends to look more like the original purple when cold and under certain lighting conditions.
If I wanted to get the better UCAs to go with my billstein 5100s on my 25 4x4 big horn- what is the mopar part number for that?
I know the UCA’s for the mopar lift kit are below, they were for all 5th gen rams. But when I order that specific part on the mopar store, it states that it won’t fit. Any reason why the mopar lift kit UCA’s won’t fit on my ‘25? Supposedly the same lift kit is for the 25’s as well. Is it the engine difference? Sorry, I’m not so mechanically inclined.
Left- 68323530AA
Right- 68323531AA
I ordered one from allmoparparts and supposidly it's been shipped fingers crossed.
yea I went and checked mine and it looked way darker then the bright purple the last time I checked it. I'll admit has probably been a month or so since I popped the hood.
Another new update today its for the ram app . Every time i cycle to acc a couple times without starting i get a new update .Also trips are not showing up anymore on the app. I will give it a few days if it don't comeback o boy.
Confused.... you got an update to the Ram app on your phone? Or just updates on the truck?
I'm curious why some are seeing updates and others are not (like me). My only guess is that's a combination of when the truck was built and the geographic area.
I received a notification for an update on the truck this morning when I pulled in to work. Haven't gone back out to see if it was successful or not. It did say this update adds new features to the truck, not sure what that means. Last time I had an update and was not at the house the update froze up the screen. Just FYI, if that happens, I had to hold in the volume and tune button for an extended period to reset the uconnect.
I'll head out in a few minutes and see if it actually worked and let you all know.
I had the update as well today, the installation was successful, however, when I clicked on the details I just got a blank screen. I have no idea of what was updated.
Update on uconnect in truck the new feature was to work better with app and now my trips are gone from the app.
