Newest software version of 2022 12 inch radio?
Mine updated too. I started driving before I could look at the change log. Anyway to retrieve that? I did notice a few of the updates noted, auto start/stop button, climate in the upper corners. What else?
Check post #16 - image of the change log.
This sucks…. Mine updated today as well, immediately after I had a whole new towing page, new temp icons, new start/stop… and once I shut the truck off and restarted…. It’s all gone. Wtf !?!?
Which new towing page are you referring to Bay Area Ram? Mine had all of these less the auto start soft key before said update and it appears we have pretty much the same truck minus the color and bed length. Mine did the update as well several days ago, but I haven't had time to go fumble thru the menu to see what's new. I do know that directly after the update, it does take some time for the icons, climate control system, etc to repopulate.
This one….. never had this before.
Gotcha. I had an additional page setup on main display that had navigatio and some gauge info for towing prior to this update. Those pages you posted were deff not in mine before however. It's been 2 days since I got the update so it appears those pages stuck. Freebies!
I had the same issue right after my update and of course just like you the page disappeared. I think it’s because if you don’t have the trailer tire pressure monitoring module, and if your truck originally did not come with this option, then it will automatically detect what your truck has and then just revert back within 24 hours.
I had the same experience. So, my 2022 Laramie didn't have the Trailer TPMS system, but I had the correct wiring harness to the rear of the truck and behind the backseat. So I added both modules (plus a custom wiring harness in the rear) and used JScan to tell the truck I had the Trailer TPMS. I see my trailer tire pressures on just my drivers EVIC. It has been a few days since my OTA update when I saw the new page, but its still gone now. I was hoping it might show back up.
Just got notified on my screen today of another update. Seems a little odd to have to back to back like that. Anyone else get one this week and have you installed it yet?
U29.44 was a screwup update sent to 1500’s in error. What version is your radio on now after this new one?
Hi Jimmy! What is the stable version as of now if you know? TRX forum is on fire, some of them got updated to 35.something and it is showing the RHO in performance pages. I Removed my telematics box module so I’m still on 27.46 and no issues.
- 27.46 is the latest stable version.
- Then they sent U29.44 to 2022-2024 trucks last month. That’s the one that screwed things up for TRX owners, and doesn’t belong on 1500’s.
- @uncc_99xj claims to have gotten back to back updates, so waiting for him for confirmation that he first received U29.44, then received something newer
- Then @ajairo chimed in and said his updated to U35.26, but that is also a version the 2025 trucks have been receiving. So, need confirmation from @ajairo on what year the truck is.
What was screwed up about it? Mine told me update failed a few times and then finally took about a week later, so I have 29.44. I can’t see any difference between that and 27.46 that I previously had.
Mine is a 2022.
Thank you Jimmy! Hope all is good. My coworker got his updated to 29.44 couple of weeks ago and is missing some gauges in the performance pages but seems like everything else is working fine.
I haven’t run it yet. I was trying to wait and see if there was any feedback from others here but I’ll probably let it run tonight. 29.44 is what I’m on now.
