Newest software version of 2022 12 inch radio?
Mine updated to 35.26 but is exactly the same. Anyone noticed any changes?
Nothing of note...mine was pretty stable the last few updates. I did notice it reset Alexa at the top pull down, and changed my auto parking brake to off, but that's about it.
Same here...had to swap Surround Camera back for Alexa.
My Surround Sound switched Off for both recent updates and I had to turn back on.
My Floorboards showed "Stored" Mode and wouldn't take "Auto" Mode..but worked as thought they were in "Auto" Mode.
Also..very strange..initially, programming was showing me all the Air Suspension tabs even though I don't have it...WHO programs these updates??!!
Mine failed a couple of times but then went through.
Mine ended up failing 4 times, but finally took on the 5th one. It did reset some of my settings, but nothing major. I'm now on 35.26
I had to put my surround camera back up in place of Alexa as well. Today I was out running a couple of errands and at one point, I look down and normally I have the navigation on my cluster. Not that I even use Uconnect navigation. I usually use CarPlay, but all of a sudden it wasn’t there. Hopefully that’s just a one off. Overall this update doesn’t seem to have done anything . Still as laggy as it always was.
So, I've had the most recent update for several days now. Found one bug so far that nobody has mentioned yet...
-Remote start/push button start vehicle.
-Let idle for 4-5min.
-Drive vehicle for 5-10 min and switch off.
-Restart vehicle in less that 30 min and Uconnect will reboot itself after everything populates then never fully recover. You will have audio however so that's nice. Display never really settles however. Screen bounces back and forth like it's loading the home icon bar but it never loads untill after you've performed a key off cycle for at least 5 min.
I've already tried several soft resets and power cycles on the display. So far no progress.
You'll need to do a factory reset, mine was doing the same thing.
If that’s true that tidbit should be included with the update.
Still ridiculous this needs to be done. Those software engineers at Stellantis are a joke.
Has anybody else had problems with their radio staying on after key off and drivers door opened?
Mine started doing that after the previous update before this most current one. I had to go into my settings and change the off delay to zero. Never had to do that before. I previously had a 45 second delay after key off but radio always turned off when opening the drivers door.
Mine started that with 29.44. If it stays on I close the door and restart the truck, then shut it off and the radio has turned off when I open the door for the second time. Pretty disappointed with this as i almost missed it a few times and wonder if that may lead to a dead battery or if it will eventually turn off? I’ve had the error -4 and -5 for the last week, but so far no update beyond 29.44, so hopefully that will be a positive if this issues if resolved.
My 2024 Limited said it was updating when I got out of my truck last night. This morning, the interface was all messed up the first time I started the truck...no temperature numbers for climate control and the physical buttons didn't work, category buttons at the bottom of the screen were completely absent (just blank space), and the entire interface kept shifting up and down as the top status bar kept disappearing and reappearing. It was so messed up that I couldn't control anything.
I tried a soft reboot by holding the two dial buttons but that didn't help. Turned the truck off and restarted, and that didn't help either. Entire infotainment system was borked, but I had someplace to be so I just started driving. The truck was off for about 45 minutes after I reached my destination. Fortunately, when I started it back up the next time, everything seemed to be back to normal. Fun morning
Yes I had the same thing what a fun time I sat there resetting it and messing with it and then just gave up in about 45 minutes to an hour later I got back in and it started up like regular I also did notice that before that I had some towing pages which I was sad to see went goodbye
I have a 2022 Ram 1500 Big Horn with the 8.4 inch Uconnect 5 system and my radio isn't shutting off anymore when the engine is off and the doors opened. At least it only stays on for about 20-30 seconds until actually turning off. I know an update happened since the icon in the top bar next to the inside temp changed from my WiFi button to the profiles button. This happened about a year ago too after an update. Then I believe another update fixed it. Didn't have any other problems until this last update. Really wish the stupid new vehicles weren't controlled by software. We are at the mercy of the software engineers.
As an IT Engineer, I know how updates can mess up a system.
It's the radio doing updates - the radio stays on while it's updating. Mine did that twice for 29.44 and 35.26. It has never done it since or between updates which were several weeks apart.
I had that happen a few times on older versions. I haven't actually seen it do that since about 26.17.
First time I’ve seen this in 3 years. Quite a few UC 5 updates during that time.
I don't think it's the radio updating. I have 29.44 and it's been doing this for about 2 weeks almost every time I shut off the truck. The radio used to turn off when opening the door and now 9 out of 10 times it will stay on. I found if I push the radio power button (the volume dial) twice it will turn it off. In my settings I have it set to a 45 sec delay. The one time I walked away and left the radio on, when I checked it a minute or two later it was off. Maybe it's doing a 45 sec delay regardless of the door being opened or not? I'll test that theory later today...
Also, I have the weird bug someone else mentioned with the power step. It shows as off (or stowed?) in the settings and it won't let me change it, but it's working normal.
I have not tried a reset yet.
Mine started this with 29.44, tried to update every day for about a week straight and failed every time, and hasn’t tried to update since, so I’m stuck on 29.44. The radio does shut off on its own eventually, or if you switch to WiFi updates it seems to shut off normally.
I still haven’t gotten the OTA update and I’ve ridden around in my truck a fair bit over the last few weeks. Tried connecting via WiFi, too, and still no update.
  • Back
