RamTruckMan
It’s absolutely not about facts. Facts are fine.People state facts here, sometimes, the truth is hard to swallow.
It’s the name calling that’s bothering me.
I’d just like to keep things civilized
Yes new ones have a lot of problems and its sad cause they cost more now. Seems to be when they just can't replace a part and fix it the problems begin. So i am praying 2026 hemi no mds no e torque .2021 was the last good year
And you going with a Chevy with a high engine failure rate?I'll cross my fingers for you and for a change or improvements or something different from ram/stellantis.
I'm going to be pulling the trigger on a new truck (Chevy) here real soon before dropping my ram off at a dealer and if they're able to fix it all within the remainder of 30 days then I'll sell it, I just can not and will not sell it private party with the issues it currently has. If it's out of commission for about 20 more days I've met the lemon law requirements and will go that route.
Maybe I'll revisit ram in a few years as these trucks do have a couple of good qualities, but too many problems and undependable at this point, at least for me. (Sorry if this post hurts anyone's feelings.)
In most cases, selection is highly subjective as to what is 'better'. And as many problems as Rams clearly have, they still are either favorable or average in most rack and stacks. Sadly, one bad experience does a solid job of crushing a brand. I was an avid Ford fan, owned at least 6 different F-series, but was soured when my diesel F350 had the bed rust out because Ford in its infinite wisdom used a 'fabric' heat cloth on the underside of the bed to protect it from exhaust heat, this trapped water, and rotted the bed out. That however wasn't the only thing that made me leave Ford, Rams have a considerably better interior design which was a winner for me. All that rambling to say, I get why people thing "this is crap, and this is better".And you going with a Chevy with a high engine failure rate?
Currently, the 2025 is unable to be upgraded, sorryHi, I have just bought 2025 RAM 1500 Rebel. it's installed with only rear view camera! I am looking for 360 Surrounding Camera Front & Side camera. any Idea where we can get one.
Yeah, on 2025+ CAN bus is encrypted, no mods possibleCurrently, the 2025 is unable to be upgraded, sorry
I hear ya, absolutely personal testaments carry a ton of weight. I get people's perceptions.I have both a 2015 chevy and a 2019, and there's a 2014 in the immediate family. These trucks; do not leak water into the cab, do not have loud wind noise in the cab, did not have both fuel pump failures and coolant leaks within the 1st 300 miles, nor did they need stabylizer bars replaced when new to prevent the rocking/tuna boat feeling when going around corners, they're able to be ran through the car wash without needing to turn the climate control to recirculate and/or the defroster off to prevent water from soaking the cabin filter, neither keeps disconnecting from a phone's bluetooth every few minutes while driving, they don't surge when idling, and when shutting the doors the door panels don't bounce back and forth and twang as if the metal is super cheap or that they're not built correctly. Neither one is internally "using" antifreeze, nor does the oil in the chevy's smell like gas like the ram. So yeah, I decided that instead of trying to block out all the issues that ram has and make myself believe it's all ok....I'll go with a chevy with "high engine failure rates." If you're talking lifters, I've seen those diagnosed and replaced in half a day, by chevy/gm techs that actually seem like they've had some training and know what they're doing. My previous post was going to be my last one here as I'm really not interested in rubbing people the wrong way which seems easy to do unless a person only posts positive 2025 ram reviews, but since you asked a direct question I thought I'd respond. No harm no foul, good luck to anyone that has not had issues with your 2025 rams, and good luck to those that have had issues but feel the defects these 2025 rams have are acceptable.
It is interesting to me that they still are favorable or average as you mention, I'm not disagreeing as I believe you are correct....for now. But from all the people I've talked to about these rams ; cdjr techs/cdjr sales/gm's at a couple different cdjr dealerships/independent techs/shops/lemon law attorneys/businesses with multiple vehicles/friends/family.....I honestly think ram will drop from that favorable/average rating when more people get their hands on these 2025's (and likely 2026's+) and when more people become aware of all the issues they have. Plus didn't stellantis just lay off a bunch of people? That likely won't help, unless it was the entire quality control department which I don't think really did anything anyway.
Mine will hit a year in August, at my current rate I should be around 20,000 miles.I will have had my 2025 one year next month and just over 10,000 miles. So far I have had 0 issues with it.
I don't think people have a problem with someone saying something negative about Ram, but you sound understandably disgruntled and do seem to generalize your issues to applying to every Ram. Ram sells a lot of pickups. I have had 3 Rams and never had any of the issues you listed above. Ford, Chevy, Ram, they all have pros and cons and they can all do better with consistent quality control. I was seriously considering a GMC Sierra before this last Ram purchase. Almost had a deal at one point, so I was very close to purchasing. I was a little unhappy with what I considered to be the underpowered 5.3L and then the 6.2L scared me because of the high rate of lifter failure. I read a lot of posts in other GM forums and GM Facebook pages from GMC/Chevy owners being as disgruntled as you sound and others that were happy with their truck. In the end, I was still willing to take a chance on a GMC but just never got the deal I was looking for. Eventually I ended up in my current Ram and overall I have been happy with the decision and feel like I made the right choice for myself. I am not here to tell you that Ram is better than Chevy or Ford or vise versa, just that for your sake, I hope you end up in the right truck for you that you will be happy with. Good luck and sorry to hear about the issues you have been having with your Ram.I have both a 2015 chevy and a 2019, and there's a 2014 in the immediate family. These trucks; do not leak water into the cab, do not have loud wind noise in the cab, did not have both fuel pump failures and coolant leaks within the 1st 300 miles, nor did they need stabylizer bars replaced when new to prevent the rocking/tuna boat feeling when going around corners, they're able to be ran through the car wash without needing to turn the climate control to recirculate and/or the defroster off to prevent water from soaking the cabin filter, neither keeps disconnecting from a phone's bluetooth every few minutes while driving, they don't surge when idling, and when shutting the doors the door panels don't bounce back and forth and twang as if the metal is super cheap or that they're not built correctly. Neither one is internally "using" antifreeze, nor does the oil in the chevy's smell like gas like the ram. So yeah, I decided that instead of trying to block out all the issues that ram has and make myself believe it's all ok....I'll go with a chevy with "high engine failure rates." If you're talking lifters, I've seen those diagnosed and replaced in half a day, by chevy/gm techs that actually seem like they've had some training and know what they're doing. My previous post was going to be my last one here as I'm really not interested in rubbing people the wrong way which seems easy to do unless a person only posts positive 2025 ram reviews, but since you asked a direct question I thought I'd respond. No harm no foul, good luck to anyone that has not had issues with your 2025 rams, and good luck to those that have had issues but feel the defects these 2025 rams have are acceptable.
Well said.I don't think people have a problem with someone saying something negative about Ram, but you sound understandably disgruntled and do seem to generalize your issues to applying to every Ram. Ram sells a lot of pickups. I have had 3 Rams and never had any of the issues you listed above. Ford, Chevy, Ram, they all have pros and cons and they can all do better with consistent quality control. I was seriously considering a GMC Sierra before this last Ram purchase. Almost had a deal at one point, so I was very close to purchasing. I was a little unhappy with what I considered to be the underpowered 5.3L and then the 6.2L scared me because of the high rate of lifter failure. I read a lot of posts in other GM forums and GM Facebook pages from GMC/Chevy owners being as disgruntled as you sound and others that were happy with their truck. In the end, I was still willing to take a chance on a GMC but just never got the deal I was looking for. Eventually I ended up in my current Ram and overall I have been happy with the decision and feel like I made the right choice for myself. I am not here to tell you that Ram is better than Chevy or Ford or vise versa, just that for your sake, I hope you end up in the right truck for you that you will be happy with. Good luck and sorry to hear about the issues you have been having with your Ram.
Thx .. Interesting, I can see provisions and demo cameras installed!Currently, the 2025 is unable to be upgraded, sorry
That may be a different thing. @Jimmy07 said something about whether or not the others were visible…Thx .. Interesting, I can see provisions and demo cameras installed!
Just a million GM V8s recalled because of engine rod bearings being faulty. That's a little excessive for a powertrain failure.In most cases, selection is highly subjective as to what is 'better'. And as many problems as Rams clearly have, they still are either favorable or average in most rack and stacks. Sadly, one bad experience does a solid job of crushing a brand. I was an avid Ford fan, owned at least 6 different F-series, but was soured when my diesel F350 had the bed rust out because Ford in its infinite wisdom used a 'fabric' heat cloth on the underside of the bed to protect it from exhaust heat, this trapped water, and rotted the bed out. That however wasn't the only thing that made me leave Ford, Rams have a considerably better interior design which was a winner for me. All that rambling to say, I get why people thing "this is crap, and this is better".
