Etorque generator noise
Does the whine you hear change pitch with the downshifting when you're decelerating and coming to a stop? My 2022 Laramie has a faint whine that does that when I'm coming to a stop. I haven't seen any issues beyond simply hearing the whine. So I haven't really been overly concerned. But I have thought about letting my dealer take a listen and see if they might find something not quite right. Hope they figure yours out. Post back any updates!
Mine was making noise like that. Seemed like on shorts trips it was more prevalent. Once the bearing got warm the noise would go away completely. My dealer didn't hear it at first but I replied I wasn't taking the truck back till the noise was confirmed.
So they did eventually hear it? What is the cause and was it anything that needed corrected?
The bearing in the unit was failing. The tech heard it and they replaced the unit under warranty. I was at 57k miles and didnt wana get stuck out of warranty with a failed unit.
Owner 2021 ram 1500 limited night edition with 8300 miles. Since purchase I started hearing whining noise between 500-700 rpms. Took to dealership of purchase and they said it was normal after having me sit in another Etorque. They said it’s related to generator charging hybrid battery while idle. I somewhat reluctantly agreed but annoying sound continues. I am still in process of investigating into this. Does anyone else with Etorque 5.7 L hemi have this problem? I’m planning on driving this truck for many miles but concerned this noise is associated with problem that may come up later after warranty expires $$$$.
Also for truck at price point of 72K it seems not right to have such an annoying noise to be normal.
Hi, I have the same issues as your truck. I own ram rebel 23. Any update about your truck? Did they find the problem and fix it? Thanks
They replaced my generator unit under and 2 manifolds under the 8 year/80,000 federal emissions warranty.
This is funny. I just took my 2020 RAM in to have the etorque changed for the whining whirring noise. After the tensioners and MGU were changed, the noise is still there. They also said it is normal and invited me to listen to another RAM. I guess I'll just be happy with new parts and ignore the noise now.
Sounds like a lot of these trucks have the same issues. I have a 2021 Ram 1500 5.7 eTorque and mine is making this same loud whining noise. It just started doing it a few days ago. @RamCares
I have 1500 Bighorn 2021 just hit 50,000 miles. Same issue hearing strained whining noise around Etorque. Dealer says there's a recall associated with it . Power train control module software (reprogram) (?) Dropped truck off and finished within 2½ hours with oil change. The problem seemed quiet, Only prob is after I got back around home and in a parking lot going slow the noise got louder, again. Still wondering what it is? ETorque or MGU (Motor Generator Unit) or what? I'll be giving my dealership another call tomorrow or day after
I’ve read all the threads but nothing seems conclusive so I’m reviving this to see if anyone else have come to a conclusion.
I have a 2020 5.7 etorque with 48k miles. When I come to a near stop and full stop, it’s only then I can hear a faint whine. Nothing crazy loud but have been reading here that a lot of people hear “nothing”.
It sounds like a faint version of this at deceleration to full stop. The sound kicks in about 10-0mph and idle.
Anyone have any insights?
Thats not normal ,i have etorque and mi e is quiet
It’s the MGU, mine has the same problem with whining noise, in the dealership since Feb 14th, the part is on back order, good luck.
Dropped it off on Friday, said the mgu unit should be in on Monday and my truck should be done by the end of the day.
Dropped it off on Friday, said the mgu unit should be in on Monday and my truck should be done by the end of the day.surely hope they don’t
you are extremely lucky if you can pick your truck up already next week, wish they can call me and say the same thing, the ETA is April 18 for mine, fingers crossed.
so what I'm getting out of this is the faulty units/bearings are so common the dealer thinks it's "normal".
replace a bad part with another bad part don't fix it. just because it a new MGU don't mean it a good one.......
i wonder how much testing/miles were done during R+D.
