Wow, I didn't know that and with the digital dash, I would have thought that you'd have more options
It is a far cleaner look in the 2025 Limited, but as the model name suggests, it is "Limited."
now thinking I want to add those molle panels to mine, got a link for them
The extender came with the panels and it’s made by Trumgeta, but I don’t see it listed on their website yet for the Ram 1500. They sent me this one to test fit and take photos for them, so I imagine it’ll be posted soon. I’m not sure if they sell the panels separately or not, but they might if you contact them.
thanks
Assembled and Bolted up the prototype Hidden Winch & Skid plate Combo I've been working away on. to test fit. Cant wait to finish welding it and color match it to the bumper. Then to pull out some jeeps.
From my understanding, you can to manually configure the fusges and displays, much like how you can select what info displays on the small guahes on the holder 7" cluster
If this is true, I would be grateful for it. I have fiddled with different configurations, but I cannot get the clock, outside temperature, engine temp (actual temperature, not a sliding scale), oil pressure, fuel mileage (instant), fuel range, and voltage all on one screen. I will investigate and continue to fiddle with it. If anyone knows how to get all of this on the screen of a 2025 Limited like I had on my 2020, I would be grateful.
I booked my 2019 ram 1500 in for a peace of mind inspection because my warranty is almost up. I have 91,000 kms and in May it will be 5 years since I purchased the truck. I asked them to inspect the driver side exhaust manifold because I suspected it was cracked (passenger side already cracked and waiting on a manifold) It turned out driver side was cracked and they had manifolds in stock! I got both manifolds replaced. The Truck checked out good. Front end is tight, there are no leaks and the brakes were 10mm still (original brakes). I am loving how quiet the truck is. Hopefully these manifolds last a while but I've already got a set of BD Diesel manifolds to put on when they do fail. Happy day. Treated her to a full tank and a run through the touchless wash.
wo
Would this work on a 2021 Rebel?????
Really digging the no fender flare look too. I can tell during winter how much debris and crap gets in between my stock flares and the fender because of the crappy adhesive placement and lack of a proper seal. Makes me not even want them at all.
The no-fender flares is a great look….if you own a paint shop and have nothing to do. LOL
Replaced my front axle lock actuator harness today due to knocksnin the insulation. Have been getting random service 4wd lights. Took it to dealer last year and they said the wiring was damaged and quoted me a $400+ repair. This was only damage I found. Took my 6 months to finally look up the harness and order it. FWIW, it's a $25 harness. And took less than 5 minutes to replace. There's a guy on YouTube that sells a "repair" kit for the connector that he charges $30 for, where you cut the damaged portion of wire of and crimp new pins on.
There was absolutely zero oil inside the connector from oil changes.
Not sure if this will fix my issue. I think my actuator may be part of issue as well, because the part of actuator the connector is on wiggles. At some point, probably during one of my off-road excursion, something must have gotten past the Vice Design front skid plate and hit the actuator by the connector.
View attachment 199083View attachment 199084View attachment 199085
400 to replace that small harness is nuts. Then as you suspect it might only be one part of a larger problem. Been there done that.
Dealer made it sound like it was a part of a larger harness that needed replaced.
None at all. Not sure about the interstate yet. Highway speed is fine. It's a pretty tight fit.
Just took it through the carwash. Not much leaking. Normal corner stuff you see with just about any cover. I'm giving it some settling time before adjusting and additional stripping in the corners. It's fine now. It's what I expected. I had read the Paragon was much worse fore leakage .It wasn't.
Update: No noise at interstate speeds.
