HELP! - Limited DRL LED Accent Light Not Working Only On Drive Side
The bottom on my driver side has a mind of its own. Some days it comes on some days it doesn't. Some days it comes on after turning a blinker on or locking/unlocking the truck.
It was not that difficult to remove the headlight assy. Maybe one hour to remove it and another to install. Here is a very detailed video on how to do it.
Hello curious as to what you did regarding the headlights with the drl having the issue on driver side and out of warranty not having much luck finding a new headlight that is not damaged any insight would be appreciated thank you
Has anyone found any solution to this if you’re outside of warranty? I am wondering if you could just replace the board. Mine has 85,000 miles and is currently having the issue with the driver side accent light. It turns on for a second and then turns off
I know it's been a few years but I just read your post. Where you able to find a fix for your driver side accent light been out? I'm having the same problem also driver side. Thanks 20250328_194102.jpg
Morning, where you able to find a solution for your accent light not working?
I haven't had time to do it. I am hoping to get to it in the next couple of days. I'll keep everyone posted.
Any luck changing the headlight ballast on your 2019 led ram?
I’m pretty sure this is not cause by the ballast. The ballast is solely for the hi/low beam. I have not changed on my ram but changed a ballast on my wife’s Pacifica when her low beam on passenger side died
Has nothing to do with the ballast, that is an LED strip, integrated part of the headlight and not repairable by most of us mortals.
Not my image, found it on the net, credit to who ever took it.
Mine is still broken. Gonna inspect the wiring harness and hope it's in there. One guy said that was his issue.
