boogielander
- Jun 29, 2022
doing it correctly is the way.This Is the way.....
hmm not sure what alignment spec was like since I have no idea where I threw the sheet.Man, fantastic write up and fantastic rig. Summarized in one page things that I spent weeks looking for! I've got a '24 Big Horn 4x4 on the same Methods with 35x11.5 Falken AT4s. I went with the Eibach Stage 2 kit all around. Some KSP UCA's until I change them to something better soon. Not afraid to admit my truck spends the majority of time on pavement, so on road comfort was what I was more focused on. Definitely trying to gear toward long road trips during ski season.
Anyway, I'm wondering what your alignment readout looks like? My dealer can't seem to get mine right. Originally they did OEM "Steel, non-lifted" alignment parameters with the 2" spacer pucks on 33" AT3Ws, which drove really well for E-Rated, 10-ply tires.
The current setup is aligned within the "Lifted Rebel / Off Road" parameters with the Eibachs at a moderate lift (2 5/8") with 35x11.5 AT4Ws, C-Rated, 6-ply.
It seems the major difference is about a degree difference in Caster. In the first setup (2" lift w/ 33s) it was near 5.1*/4.8*. The current readout after abut an additional 1/2" of lift in front and 2" larger tires is 4.1*/4.3*. Other parameters are all nearly the same.
Seeing if you, or anyone else with a similar setup, has dealt with this? Get a decent amount of seat/wheel vibration and dribble between 30-40 and 65-75 mph. No clank, noise, or otherwise. Steering is a little bit sloppy feeling. No real drag one way or the other. Just trying to get to the culprit of the issue. It could be tires, it could be alignment, it could be something else. Should note, the tires balanced (Road Forced) fine with scores all under 25, granted, it took 2 tries.
Thanks!!
nope i left it where fox left it and it's around 2" compared to non Rebels and non ORG for maximum droop and suspension travel.Are you running the front at the full 3in? i read a comment you did on a different thread saying it was a stiffer ride at 3in.
I concur, and Justin at Accutune also told me recently that the 883-06-166 are 2-3" advertised, but you really don't want to go over 2.5" to avoid what you describe.nope i left it where fox left it and it's around 2" compared to non Rebels and non ORG for maximum droop and suspension travel.
set it to 3" you will have less suspension travel and less droop.
yeap exactly!I concur, and Justin at Accutune also told me recently that the 883-06-166 are 2-3" advertised, but you really don't want to go over 2.5" to avoid what you describe.
Very good to know, thanks!yeap exactly!
oh and when you order accutune, i highly recommend go with their most aggressive tune you can get even if they tell you not to. that happened to my friend on his taco and let's just say our group will never use them ever.
that's a negatory.I see RAM TRX wheelsets floating around at a reasonable price. This set comes with 50% tread tires. Would they work as a substitute under your setup (or mine, Stock 2021 Rebel), or is the offset incorrect without spacers? I like your setup. Perfect for Utah / Wyoming. Need to follow your recipe. Not against the missions (it would be my first after-market pick), but I'm leaning toward keeping a stock look if possible, plus trying to manage the $$$. So much you can do to a stock Rebel (Ordered a Lone.Peak Overland Camp Top production complete date scheduled for late May. )
It looks like the factory 2022 TRX wheels have a 19.05mm offset. Will the Truck be drivable before I get the Fox 2.5 DSC and the Carli UCAs. Thinking I would get some rub on full
TRX and rebel should be same, if not similar, offset. they are positive offset so doesn't matter which one it is, you'll need spacers. i hate spacers as well, so just do -12mm wheels lolllRethinking the 35s. Looking at the BFG K03 in a 295/70/18 that will be a solid 34. Are the TRX and Rebel wheels the same factory offset? Like the black factory look. Would the 295 still need a spacer in the factory wheels? hate the idea. Would they be -6mm? ~$2k
Sounds like the Fox 2.5 is a great platform. Would you recommend a 500 or 550 coil if you are adding a wench and hidden mount (Hidden Winch Mount | 5th Gen | 2019-2024 RAM Rebel) and balance load of some sliders
Thinking parts are running $5K would $1k in labor cover the install IYO? ~$6k
I hope LPC will come through. I completely agree that GFC have the best bracing for an offroad cap / tent. I will likely get a local fabricator to beef up the bracing in the LPC that should help some.
GFC LPC 90 x 56 = 35 sqft for $12k
LPC 120 x 56 = 46 sqft for $8k (33% more floor tent area before the rear pop out which looks to add another 50+% volume. I'm 6'5 so space is a good thing ) The $4k goes a good distance on the suspension.
Sliders ~$1K, Winch / Hidden Install / Lights $3k, Ancker Frig & Power souce ~$1K, DYI Storage ~$1K = $20k project
