Led tailgate light bar on 25's trailer light errors
My lights are actually typically used for emergency vehicles, I'm just using them for another purpose since they're insanely bright and very sleek look. They are LED. I did not have any tailgate lightbar or anything. I initially just wired my new lights to the trailer wiring since the wiring is right there and easy to access. But the dash errors weren't going to work so I tried wiring to the tail lights instead and that cleared everything up.
Thanks for the info. I'm getting the same errors Kilroy got before his ingenious module fix. I'm not an electrical engineer (let's just say I turn off all power to the entire house to change out a single power outlet), so I'm hoping to find a solution that does not require me to wire my OPT7 into each light.
So I had an OPT7 60" Redline Triple Row LED Tailgate Light Bar w/Sequential Amber Turn Signal on my 2021 Limited, so before I traded it I took it off along with the 7 pin to 4 pin trailer connector adaptor. It has a 7 pin male connector on one side and a 7 pin female on the other, you unplug the trailer connector from the back side of the bumper, and place this cable between the original plug and the socket (Back side of the bumper). The you get a pigtail with a 4 pin connector on it. Then you can plug the led light bar into that. My bad for not "testing" the setup before installing, but now with the light bar plugged in, I get an error on the dash indicating there is a problem with the trailer lights.
I have seen on OPT7's website that they had issues wit hthe turn signals not working on the newer F-150's and the sell a cable system that plug in between the tail lights they call it vehicles with (BLIS), however the light bar works perfectly, brake, turn, hazard, and backup lights from Genron. Any one had a similar situation on the newer RAM trucks?
Just got my '15 Screw Platinum. Had an aftermarket tailgate led light bar (the strip that goes below the tailgate, between it and the bumper) and they plugged it into the trailer wiring harness recepticle in the bumper. When starting the notice comes up on the instrument cluster indicating trailer attached which you can dismiss but this recognition causes a number of features to be disabled like the blind spot intervention and several other things. I cannot find anywhere to override this in the settings and the Ford service guy who I asked to contact Ford to find out if it can be done (not sure he really made a full fledged effort) says they said "no." Anyone know what I can do? If they splice and hardwire will I still get this problem? I don't want to take any chances messing it up but I liked my light bar on my '13 F150 and there weren't these problems--then again it didn't have all these features. Appreciate any/all help.
If you have a '15 Platinum (Ford), OPT7 makes a specific wiring harness that works around the issue you are describing. This is a Ram forum, and OPT7 doesn't to make a specific wiring harness for Rams to correct the same issues we have with our trucks.
OPT7 makes a wiring kit for those that connect to the tail lights that should fix that issue.
I am working on a wiring harness for the RAM trucks myself, details this weekend.
