Spark plug change - 2019 Ram 1500 w/ 5.7
I thought the were actually pretty easy to change when I did mine. They are all on the top of the engine so access is pretty simple. The swivel socket is a must. I know it needs to be smaller diameter than a standard spark plug socket to fit through the hole in the valve cover.
Easy but a pita I had to buy a swivel socket and a magnetic retriever to hoist down the spark plugs in the back cylinders haha
They weren't difficult at all...Used a magnetic swivel socket...threw an old blanket over the motor and laid down on top and knocked them out in about 45 minutes.
This isn’t the infamous Triton V8 w/ the spark plug issues. A swivel and small extension is all you need, you’re not going to break a spark plug unless you’re a cave man. I think you guys gotta go wrench sometimes and stop psyching yourself out thinking you’re going to do something wrong. Also you shouldn’t be having to swap them out until around the 100k mark.. iridium plugs after all. It’s not the old every 30k method unless you’re running into issues.
I’m not sure why you would refer to them as inferior? I changed mine last summer and put 10k or so on the truck and they’ve been great.👍🏽
Old mopar plugs @90k
I suppose I should have added I was being sarcastic. The quality of those plugs speak for themselves. I was only voicing what I would expect EVERY dealer to say. In fact, I installed new AC Delco plugs in a friend's 06 V6 3400 Impala. Later he took it to a dealer for other work, and the actually SLAMMED those AC Delco plugs!
etorque, but shouldn't matter
I just did mine with the E torque it does make a diff you have a support bracket on drivers side that only can be loosened not removed and it is a son of a gun to slide around to get to coil packs. the video on this thread is the one I used , the drivers side will take a few hours just take your time.
took me longer to get that bracket out of the way then to do the last 2 coil packs , 😂
I have to say my B\S detector is on and no way you did the 16 plugs on the 5th gen hemi E Torque or non in 45 minutes , Bull **** !
HMMM i did my non-e about that fast. the biggest fight is the 2 closest to the firewall that sits under the booster. other than that, its a breeze. used my Milwaukee ratchet and zipp zipp ole son!
Cool Bruh...learn a lot working on planes for 20+ years, mainly digging in and getting **** done and not overthinking it. 6 of the 8 cylinders are free and clear of obstructions. the aft cylinders on the drivers side are tough but no where near as difficult as people make them out to be. Like I said, thrown a blanket on the motor and lie down and knock them out.
Driver side definitely sucked. The 2 far back wasn't as bad as the 2 in front of those next to booster. Especially when trying to get the plug out once loose. Luckily I had a swivel I could use. I'm just glad it's done and not gonna have to do ever again. After 200K they will stay :ROFLMAO::ROFLMAO::ROFLMAO:
Can anyone post a picture or a name/identifier for this socket everyone is talking about above? When i clicked the Amazon link it switches me to Amazon US (I'm in canada) and then just defaults to the main Amazon page so I can't see what the tool is you're all using. It's either because I'm international or it's not available anymore but I'd love to know what it is so i can find one. Anyone find a torque rating for them or are we all doing the old spark plug metod of a certain amount of turn passed hand tight? Thanks!
I don’t follow the torque rating just hand tighten it with an extension then stick on the torque wrench and tighten just a little bit changed it twice and my car is at 120k miles driving like new you’ve got this!
