So being that my 2019 does not have the off road package. Does that mean I need to get the arms?A lot of info on this if you search. In short,
-With Off road package 2” level kit will be fine. 2.5” or 3” recommended and/or need arms.
- with out ORP 2.5”or 3” should be fine. Above that will need.
Do you have any pictures of the angles with the RL UCAS??I went with the ReadyLift 2” level on my non-ORP 4x4 with RL upper control arms. Sits perfectly for me (about 3/8” lower in front). I had experienced UBJ issues on my 2016 ram with only 2” spacers. After about 35k miles, boots cracked, started squeaking and grinding. I think the angle was a little much with minimal off-road driving, so I played it safe with the upper control arm purchase. Installed and aligned for $865
The back still sits .5in higher from measuring in driveway but overall higher front end as you should be able to see in pictures from earlier. First pic is back and second is front@Marcus889 sweet ride man! And thank you.
A 2.5in will put the front end higher than the back. I'll measure when I make it home to give you a definitive height. View attachment 14457View attachment 14456
Neither I have Body Armor. The Mopar Kit ($1399) is highway robbery when you can get Ready Lift or some other trusted brand with/without UCAs for alot less and not compromise quality. Plus you will still have to cut/modify wheel wells depending on offset and tiresDo you have ORP or Mopar kit?
