Need help to buy divider and tonneau cover
ram1980
2021 Ram 1500 Laramie with rambox and multifunction tail gate. Do you know where i can buy the good divider and good tonneau cover. Please give me link.
If you happen to be in the Connecticut area, I have a factory tonneau and the black bedrails needed to install it available for a fair price...came off my '24 with Rambox and MFT last year. Need to be nearby to pick it up though...would probably cost a fortune to ship.
Thanks. I am in Texas. Do you have any link for that cover?
Best place for the Mopar Rambox divider is on FB marketplace. Took me a couple of weeks searching but found one nearby. If they have the keys that will save you about $40 re-keying to yours.
facebook marketplace in my area, there are guys sell it for couple hundreds. But I don't know where i can get the key after buying the key cylinder to replace the the original cylinder in the divider? Do I need to have the key to use the divider?
You only need the key if you want to lock or unlock it. As long as it isn’t locked , you can open and close it by twisting the handle. If you are going to have a bed cover, as I do, I wouldn’t worry about the key. I never lock mine.
Probably the dealership or a locksmith could re-key the lock for your existing key.
Did you ever have any luck finding a tonneau cover. I have a 2022 Rebel with the rambox and multifunction tailgate and running into the same issue. I am also looking for a bed rug as well.
I bought the bedrug for my ‘22 Longhorn. Only issue is with the MFT tailgate. It’s ok if you only use it as a regular tailgate, but it doesn’t work if you open it like a door. I ended up just cutting off the tailgate extension part. I left a long enough of a tail to tuck it under the backend of the bedrug.
I had cut the tailgate extension into two pieces with the intent of installing those onto the doors. My wife even blind stitched the edges. After using it awhile I decided not to even install it on the doors.
What are your thoughts on the bedrug? Do you like it, is it worth the money?
I’ve had the bedrug in a couple of my pickups. I like the fact that it fills in the channels in the bed floor. It essentially makes the floor flat. The material is very durable and it can be washed if needed.
I had/have a bed cover on too, so it gets that extra protection when parked during the day.
It really depends on how you will be using your bed if it is something for you. I do have stuff in the bed. I wouldn’t throw in crushed stone or busted up cement blocks if you follow what I am saying.
