2025 Ram 1500 Current Owners - Discussion, Feedback, and Problems
Anyone have this issue pop up? “auto emergency braking unavailable service required”
Everything was working fine for the first 50 miles or so and now I can’t turn cruise control on or auto emergency braking on. Any help?
Expecting I'm going to have some gremlins too. If I do, I'm going to restart everything as step one. Check battery voltage (and replace as necessary) for step 2. Dealer will be step 3.
Forum consultation will be ongoing.
I know that probably isn't very helpful, but wanted to share regardless. Either way, I'm sure you'll get it resolved shortly.
I just had AEB, 4WD, and traction control unavailable, service required, and the CEL come on. Wonder what the issue is?
Is the Digital Key still not available or working?
Not available. From what I’ve found, they stopped giving eta’s on it. Who knows when it will come but I’m really bummed about it.
That's a bummer. I sort of pushed this out of my mind a few months ago, since I didn't have my truck and it would be a while. just assumed there were going to roll it out in October/November.
Are there any other "features" that aren't available yet?
I don’t know. That’s the one I wanted most and was aware of. I’ll have to look through Ram’s marketing material and see what they say.
Update:
I wiped the sensor and disconnected both batteries and that seems to have “fixed” it.
I've had it about 3 times so far...every time for me at least is appears to be the sensor right above the front license plate (that's a new one for me..wasn't on the 2019) has been covered with snow or slush...wiped it and the warning went away
Unfortunately, Ford does it better. They use the camera in the windshield instead of radar in the grill/bumper 🤷🏻‍♂️
listen everyone unhook both batteries for an hour at least when turning truck on put it to run for a min before starting let electronics wake up manually hit your profile and then start since i did this all electric gremlins gone but my trans is crap before i did this park sense not working blue camera screen wasn't going to my profile even tho it said it was use same key everyday i would not of bought one if i knew all the electronic went crap starting in 2023
Wish that were the case -- In in GA and mine is clean and shiny.
I used the tilt feature for a while, but like others have reported, when returning from tilt to normal, they eventually return to a position that is not where they started (viewing the sky) and not where you had adjusted them to be.
Found it super annoying after a few weeks of this too before turning off that feature.
Take a breath, man 🤣
I’m assuming the people turning on the mirror tilt feature are people without the tow mirrors? There isn’t really a need for this feature with the huge convex mirror on the tow mirrors.
Given the blind spot complaints and the tilt thing, I’m glad I decided to stick with strap-ons!
