wickedmopar
- Oct 3, 2024
see that now, thanks sir!only the front. but check this thread, post #12 has a picture and maybe you'll get others feedback
Thanks for the tip, I am going to look that up and try itWhat works really really good is a good polish (paint correction if needed) then Jescar Sealer. That S will make your paint damn near glow in the dark, then apply a couple coats of good quality wax over that.
It's made by Menzerna but labeled Jescar in the USThanks for the tip, I am going to look that up and try it![]()
Did the same thing with this adapter. I tapped mine in the rearview mirror. Power is right there.
I like those rampsPicked up another hobby unit to work on with the Limited.
Well this is a coincidence. Figured that I would search the forum for info on some good ramps and dig up some posts from a few years back... But nope, your post is brand new.I like those ramps
where did you get them?
I have the tri-fold ones. Makes them much easier to move around and store. Have used them for ATVs, riding lawnmower, and snow blowers.Well this is a coincidence. Figured that I would search the forum for info on some good ramps and dig up some posts from a few years back... But nope, your post is brand new.
I'm looking for some ramps too. I found these at harbor freight. The weight rating looks fine, but not sure what everyone else thinks about things such as the length, etc.
And then these are 4 times the price..
I’ve done this hundreds of times. Sometimes 2 at a time!I have these specifically for loading a snowblower. The longer ones make the slope a little less severe. Make sure you use the retention straps to secure the ramps. I also drive up and down facing the rear of the truck. That way if it gets away from me I'm not under it. But if you have it in gear and the drive engaged it shouldn't roll any faster than the speed you select. Strap it down good so you don't punch out your back window.
Holy crap, all that on a 2020?Had an exhaust leak fixed under warranty. 2 cracked manifolds and 7 broken bolts later... Sounds much better. Almost sounded like an old diesel towards the end.
