22” Rims on a 2019 limited with 20”
George Bednar
Central Illinois
I may have found a set of new 22” limited rims. They are factory balanced and 285/45R22. Can they be mounted on the limited with out additional balancing and with out any clearance issues when turning?
there may be fitment issues if your limited is not the same color as the limited the rims came from.
The circumference difference is around 5/8”. Would the wheel bearing difference matter?
The wheel bearing won’t make a difference. People are routinely putting 35” mud tires on the smaller wheel bearing trucks with no issue and those are much heavier than the stock 22s. The speedometer may be off a bit but since you are sticking to the OEM 285-45-22 tires the dealer will be able to recalibrate it for you
Thank you Warmachine. I looked up the speedometer difference on a web site. It said +0.38 at 65mph so 65.38mph
PS Cannonball are you referring to the wheels or bearing being round or square. HA!
