Our 2019 5th Gen Ram 1500 Laredo with 12in digital control screen - AC is stuck on blowing cold both sides in defrost mode only now, with no rear air flow either.
Trying to figure out why local shops are saying dealer has to replace and calibrate a new mode actuator.
We can't afford dealer shop rates...does it require an expensive OBD2 scanner type unit?
Is this a standard project to be easily be estimated & not require hours of research by service dept?
Any info you can share would be much appreciated!
