Tazer dt unmarry
Julio13
So I bought and married tazer dt to my truck didn’t like some of the changes I made only one I liked the gps in motion but decided to to put back to stock and unmarry I thought I had done it right but still notice I could still write address while in motion any help would be appreciated
That is a change in the BCM that doesn't need the TazerDT to be installed. If TazerDT is not in the truck, and you followed the unmarry process before removing , then it's unmarried.
Right so gps in motion will stick even if I unmarried right?
How could I tell if I did it right
Try the TazerDT on another truck
I mean it says to marry now so I guess it’s unmarried but is there anyway some changes stuck
Any changes made to BCM will stay. Like if you changed DRL location, added trailer brake controller, changed tire sizes.......
Oh ok got thanks again
When the tazer is unmarried, any changes that you used that tazer to make to the BCM (tazer vehicle settings) will go back to the way they were without the tazer.
If you leave the unmarried tazer plugged in, the live functions will still work. Nav in motion is a live function of the tazer, and that’s why it still works with the tazer plugged in but unmarried.
I don’t have the tazer plugged in
Unmarried and two sleep cycles and your good. The Nav in motion is a live function. I use it unmarried and live settings Pin Lock,amber DRL's and other stuff
The “Nav In Motion” feature is a feature that can only be used while the tazer is plugged in. It is not a setting that the tazer can change on the vehicle, because it is not a configurable setting in the BCM. The tazer has to constantly “trick” the truck into being able to do the nav in motion, hence the reason it is a live setting and needs to be plugged in, there’s just no other way for this to happen.
I turned on the turn cam to try out that's cool.
I've never fully understood the whole turn cam thing. Maybe if you have 360 cameras, but why would I need the back up camera coming on to make a left or right hand turn?
