Part number for 2500 rear sway bar that fits 1500 DT 4WD
Farmer Spring
Hi everyone,
I have a 2023 Ram 1500 Big Horn 4WD and is seeking to improve stability on curvvy mountain roads. I see Hellwig rear sway bar is popular in the forum but would prefer Mopar products as I have 8yr/125k Mopar service contract.
Therfore, using OEM rear sway bar from 2500 seems like an idea to go for me, and I have found that there seems to be 2 types of rear sway bar on 2500 (one for 2WD 68453383AB + bushing 68139764AB and one for 4WD 68453381AB + bushing 68160338AA).
For those who had experience using 2500 sway bar on their 1500 DT 4X4, could you share which one you had and do they fit well on your 1500? Thanks a lot!!
Hi everyone,
I doubt that's going to fit since the HDs are still based on the 4th Gen trucks and not 5th Gen.
Using the Hellwig will not void your warranty at all.
Not only that, but in a hypothetical situation where it would, a 2500 sway bar would void it as well since it's not a factory part for a 1500 (assuming it would even fit).
Just noticed sway bar is only connected to end link (and then frame) and rear axle. I got one today and am still adjusting to it. Rear of truck feels more planted than front now, which never happened before...
If you add a correct Hellwig front bar with better aftermarket end links (like Suspension Maxx), your handling will exponentially improve. My '25 Laramie with the match Hellwigs is far more planted and accurate than before - the factory hollow bars arguably allow lethargic handling characteristics, which in a truck this size can be scary with the wrong driver behind the wheel.
I ended up changing it to lowest setting, ride is very similar to stock and cornering is still a lot improved comparing to stock. This would probably be where I am staying...
Hellwig is ~ $267. What'd you pay for the 2500 Mopar bar?
