Do 2021 TRX wheels fit on 2019 Big Horn
The width won't fit either. 325 wide is going to contact the UCA without a wheel spacer.
IIRC the widest you can go with a factory offset wheel and no spacer is 295.
Can I run 295/70/18 with Trx rims on my Ram Rebel? I have a 2 inch leveling kit. I know there would be little clearance but is it safe to do so?
Stock TRX wheels and tires, 325/65/18 on 2019 Ram 1500 Limited. KSP 1.5" spacers installed (quite a while ago, nor for this install, wanted wider stance with stock wheels) https://www.amazon.com/gp/product/B083FD9Q3G/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Did a little doctoring to free up wheel well space, removed rear front mud guards and have no rubbing on normal height, lock to lock or otherwise. Pictures are on Normal height. I do not have a leveling kit, nor is it lifted, stock air suspension. They look meaty and to my surprise, the speedo auto corrects and reads speed perfectly again a GPS speed check.
Question on this you guys may be able to help with. I’m interested in picking up a set of just the 325/65/18 tires from a TRX takeoff to mount to my aftermarket 18s that are a 0 offset. Do you think the offset is enough to not need spacers?
Sup gang, after seeing plenty of yalls perfect setups I finally pulled the trigger and leveled my truck and put it on some fresh TRX take offs. In order to make them fit we also installed some 1.5 inch spacers and a 2 inch level (links below) The spacers are necessary in order to clear the UCA. Full turn has some rub even with the fender liners trimmed up. I might need to re-mold them to gain more clearance also open to suggestions on how to fix that.
Tires are 325/65/18
KSP Wheel Spacers: https://www.amazon.com/dp/B083FD9Q3G?psc=1&ref=ppx_yo2ov_dt_b_product_details
MOTO Fab Level : https://www.amazon.com/dp/B00I5057UU?psc=1&ref=ppx_yo2ov_dt_b_product_details
Finally got around to it, installed Bilstein 6112s up front, Bilstein 5160s in the rear, Icon UCAs, and TRX wheels and tires. 6112s are on clip #7. 1.5” hubcentric spacer in place and everything fits. Minor trimming up front to the inner fender liner but now achieved zero rub even at full turn. Enjoy, hope you like the truck and I’ve got a lot more coming.
Thanks for the inspiration man, youre post was the one that made me pull the trigger.
Tires are 325/65/18
KSP Wheel Spacers: Amazon.com
MOTO Fab Level : Amazon.com
no lie that ball joint angle on the upper looks really bad i would highly suggest getting a set of mopar 2" uca's or find an aftermarket set.
I’m about to do the 1.5” bora wheel spacers and stock trx wheels/tires on my truck here soon. Anybody running this combo have any issues after having them installed for some time?
What’s the tire size?
2021 ram big horn with 2” level and 1.5 spacers
Man this thing looks amazing, can you please share the parts and brands of this wheels setup with tire size if possible
Thanks they are factory Trx rims and tires
