Golfzilla184
- Nov 13, 2021
Help please, i found someone selling 2021 TRX wheels and need to know if they will fit my 2019 big horn.
Is this for 2wd or 4wd and would there be a difference?Doing some quick math based on the reported 3/4" of clearance on a stock tire:
295 = .35" clearance
305 = .15" clearance
315 = tire contact with UCA
325 = tire contact with UCA
That said I took measurements of my truck when looking at tires, and I was measuring a little less than 3/4" on stock wheels/tires. As a result I think that 305 was either unreasonable close or touching, so 295 is the widest you could safely run on a OEM offset wheel without a spacer.
Not to confuse things, but scottmoyer, if you didn't change the tire width and the offset is the same, there should be no difference in your clearance. Yes the wheel is wider and it will be 1/2" closer to the suspension, but the tire is the same so it will be unchanged.
To clarify:
On an 8" wide wheel the, 10.8" wide (275 mm) tire will overhang the wheel 1.4" inboard and outboard.
On a 9" wide wheel the 10.8" wide tire will overhang the wheel 0.9" inboard and outboard.
Therefor your logic is accurate that the 1" wider wheel will be 1/2" closer to the suspension (and 1/2" out too). However, if the offset is the same, the centerline is unchanged, and the wheel won't move closer/further from the suspension. The only difference is that the tire won't protrude over the wheel as far as it previously did. If you haven't changed the width of the tire or the offset you should have the same clearance with everything as you did before.
Does that make sense? I can try again if it didn't.
****EDIT:
See post #10 for clarification on wheel widths. There is a slight effect if you're using the same tire.
Do you have any exterior pictures of them on your truck? I'm looking to do the exact same thing on my Limited with the Off-road option, which I think is raised 1". I am not planning to use spacers though...@Shots, now that I think about it, you're right. The positive offset being the same on both wheels is from the centerline to the inside edge of the wheel, so +19 should give the same inside clearance. But it didn't. I lost 1/2". I looked online to find the offset of both wheels and found them both listed at +19, but are they really?
Editing this post to include "no spacer" measurement photo and the removal of the photo that didn't have a tape measure.
Here's my before measurement:
And here's the after.
And here's how it sits with 1.5" spacers. So maybe I only lost 1/4" (??)
Baker, what size tire do you have on them? Trying to figure out how to get these TRX rims on my 2023 Limited I just ordered. Thanks!They "fit" without spacers but the side wall does just barely touches the UCAs. I drove mine that way for 2 days until the spacers showed up but I only have a 2mile drive to work. It did leave a small mark on the sidewall but didnt cut into the tire. Pictured with 1.5in spacers which is over kill honestly a 1/2-3/4in spacer would be enough to clear UCAs
Edit: I should note that I have readylift UCAs which seem to have just a slight amount more clearance. Stock UCAs would contact the tire more.
The TRX wheels are beadlock capable. You can run them legally, as long as you don’t buy actual beadlock rings and flip the tires out to pinch them with the rings.I have the TRX wheels on my big horn 2022, i installed a rough country 3.5” lift kit with new front/rear shocks, and new front arms, i needed a 1.5” spacers too
I will like the beadlock TRX wheels, but i need explore more because i did read that sometimes is ilegal ride with deadlock wheels and i don’t know yet it they are the same size
I wonder if they would fit on my 2019 Ram 1500 4x4 if I were to install bilstein 6112s with readylift UCA and no wheel spacers.Just mounted a set of TRX takeoffs with new DuraTrac 285/75 tires to my stock 2019 Rebel. Tires fit perfect with zero rub anywhere. Truck is stock with no level, coil springs. Space between UCA is enough to get a finger through.
