Michelin Defender LTX M/S2
boldram
How do these tires feel on ram 1500 ? Please share with me your experience. I do mostly highway driving
I went with the original Defender LTX M/S. Its a proven tire with tons of great reviews. The jury is still out on the M/S 2 and I've read some people complain about the road noise of the M/S2 compared to the M/S
Loved mine, they just wore out too fast.
I think I only got 40k out of them. My drive is mostly highway, too.
After 10,000 miles they are very good. Much better than the OE Bridgestone tires. Wet traction is excellent and they did well in the snow. I do mostly highway driving and they are quiet and smooth.
Its a great tire have them on my wifes car and they were even on my old truck
What size? An 18" will ride much different than a 22". Do you have air suspension? That also plays a big role.
I put a set of M/S 2's on my GT back in March and had a hard time getting them balanced correctly. After a couple of serious road force balances, Discount finally got it sorted out and it's been fine since. They perform like i've come to expect from the Michelin M/S series over the years. Quiet, smooth, and all around good performance in varying conditions.
My truck has 22's but also has air suspension so the ride is pretty decent.
Have you considered Michelin’s CrossClimate2 tires? I put some on as soon as I got the Ram - mostly due to not liking the OEM tire in rain (Louisiana life). I looked at both tires and both seem great, I have a personal testimony with the CC2’s given my wife’s Pilot in which we had them on for 40k miles through Louisiana weather and even snow in the mountains and at 40k still looked new, the come w/60k warranty… biggest complaint from folks is noise, but if you rotate them regularly we had zero issue. Just a thought for you…
of note, I have 22’s w/air suspension as well and do mostly highway driving with some light hauling.
I've had several sets of the M/S across several trucks and SUV's over the years...have always been excellent in all conditions, including light off-road, however only on the RAM I notice a bit more road noise, which is surprising. I'd be surprised if the M/S2 is much different, but I'm curious if you end up trying the "2".
I recommend Kumho Crugen HT51. Great 70k mile tire, every customer I have recommended them to likes them. My dad runs them year round in Northern Michigan. Rate very similar on tire rack. They cost about $50 less per tire. Look at the two, treads are very similar.
One outside shoulder is blocked off for water exit. Ran into this problem with the OEM Falkens when worn halfway, too. The Conti HT's have 2 sides blocked, but both are fixable with my tire groover, the Conti being less noticeable when done.
The MS2 should be just an incremental improvement; I don't see the side grooves making any real noticeable difference in dirt/snow. That said, I have the regular LTX (18" E) and they wear well and work good in the rain, so much so that I don't consider driving different (pull out in traffic) and don't get into traction control either.
