275/50/22 Continental Terrain Contact AT
Scituate143
I recently had these mounted to replace the stock Goodyear 285/45/22. I wanted a little more sidewall but didn’t want to go to an LT tire. After searching high and low I gave these a go, based on the spec sheet they run wide for a 275. After mounting they are not visibly any narrower than the 285’s that were removed and offer better rim protection. I measured the tread of my wife’s 275/60/20 and the actual tread on these is about 3/4 of an inch wider due to a more square shoulder block.
So if anyone is looking for an OEM+ tire and don’t want to go with a 305/45 these may be worth a look. They measure 32.8in, and I do get a slight rub at full lock.
Also here are some pics comparing to a friends wagoner with stock 285/45/22.
I too prefer more sidewall, but I feel with the OEM 22's, we're pretty much boxed in. Not many options to go bigger that don't jump straight to "off road" tires. 285/50/22 in a highway/all-terrain tire pretty much don't exist. Heck, even 275/55/22's are ghosts. So that basically leaves us with 275/50/22. I suppose with 97% of my life rolling on Southern highways, that should probably be fine. It would be nice to have a bit more meat though (no diddy :ROFLMAO:), and to fill the wells for aesthetic reasons too.
I have used these for a while and am happy with them. The slight rub can be fixed by drilling a hole and zip tying the flexible cover back slightly inside the wheel well where it's rubbing.
View attachment 177008View attachment 177009View attachment 177012View attachment 177011
Are you still happy with the contis and the size? I’m thinking about making that same switch
Hi, I have about 5k on them and they are great. 275/50/22 is a great size in this particular tire. Offers plenty of rim protection and measures 32.8” tall. I’d say they are a great OEM+ replacement/upgrade. Traction is night and day better wet and dry. There is minimal A/T tire noise, and cornering stability is much better and no tread block sound.
I saw a Ram with this same tire in OEM 285/45 and much prefer the visual appearance of the 275/50 and the added sidewall. They look so much better than stock with no drawbacks.
