Scituate143
- Feb 15, 2024
I recently had these mounted to replace the stock Goodyear 285/45/22. I wanted a little more sidewall but didn’t want to go to an LT tire. After searching high and low I gave these a go, based on the spec sheet they run wide for a 275. After mounting they are not visibly any narrower than the 285’s that were removed and offer better rim protection. I measured the tread of my wife’s 275/60/20 and the actual tread on these is about 3/4 of an inch wider due to a more square shoulder block.
So if anyone is looking for an OEM+ tire and don’t want to go with a 305/45 these may be worth a look. They measure 32.8in, and I do get a slight rub at full lock.
Also here are some pics comparing to a friends wagoner with stock 285/45/22.
