Sway Bar Link Pins/Bushing upgrade for 2019-2022 Ram 1500
It actually makes a difference in handling. Doing just the bushings probably won't be noticeable
Alright fine... Ive been thinking about it for 1.5 years now so why not.
Did you swap the end links while you were in there or stay stock?
I'm still on stock rear end links, will swap in future, but not a priority
I swapped end links and they compliment the Hellwig tremendously. I prefer a stiff rear (lol) and it really plants the truck and all but totally eliminates the floaty body sway.
For those of you that did the energy suspension bushing upgrade. When you first slide them on does the slit on your bushing stay open a bit? This is before putting the bracket back on and tightening.
Yes
Yeah maybe a bit but once you put the bracket on it’ll close it up. Make sure to use the grease it comes with or you’ll wonder why you’re always hearing geese. 😎
Hi all, what about Mevotech TTX links, somebody tried them?
