thedadalorian
Yo gang! wanted to see if anyone can recommend a good dash cam for my 24 ram 1500?
				 5thgenrams.com
					5thgenrams.com
				With the number of people posting about 3td brake lights leaking, not sure aid want to add another hole to itJust something different to consider, I am using a Wolfbox 840S attached to the rear-view mirror and with the rear camera custom cut into the 3rd brake light (you could use a license plate bracket mount instead). This will give you front and rear recording and a digital mirror option if you wanted it... At some point I will make a post to show others.
Where did you put the rear cam?FitcamX
front and rear
I put mine on the opposite side of where the sliding window opens to. Just stuck her on there as high as I could.Where did you put the rear cam?
Yep, that's where mine is as well
yup me also
I know that everybody goes with fitcam because of the integrated housing and whatnot, but technology-wise, is it the best dashcam? for example Viofo advertises things like Sony STARVIS 2 chipsets. Fitcam doesn't really go into the nitty gritty specs.
What exactly are you wanting out of your dash cam? There isn't much difference between all the different dash games once you get into the guys of them there are like 2-3 different lens options, and only a few different chipsets.I know that everybody goes with fitcam because of the integrated housing and whatnot, but technology-wise, is it the best dashcam? for example Viofo advertises things like Sony STARVIS 2 chipsets. Fitcam doesn't really go into the nitty gritty specs.
