Correct. One click puts them on the lowest sensitivity, the other 3 clicks until you get to the top 2 settings just increase the sensitivity. As far as the Auto High Beams, your light switch must be set to AUTO, they will NOT work if you actually turn the switch all the way to headlights on. In AUTO mode, you then push the stick forward and there should be a message on your TFT screen stating that Auto High Beams are Enabled. If that isn't happening and you are SURE you have your light switch on Auto and Auto High Beams enabled in the system, then something is wrong.
They are very, very sensitive to ambient light...street lights, business lights, etc. Mine won’t come on at all in the city; I just about have to get out of town to see them in operation.I just got my truck yesterday and the Auto High Bean doesn’t work from the start even my Uconnect states it’s selected
It’s normal if it’s sensitive to street lights.They are very, very sensitive to ambient light...street lights, business lights, etc. Mine won’t come on at all in the city; I just about have to get out of town to see them in operation.
All four lamps are lit on low beams. Are you sure yours are on high? (Sorry if it's a stupid question...)Weird.
Mine just won’t dim, it act like a normal high beam
You have the opposite issue to what everyone else has experienced. Most have observed that the high beams rarely come on unless they’re in pitch-black countryside.the blue indicator went on , so I am sure it was high. Plus I can see the differences when it light are projected on the road.
Are your headlights set to "auto" or "on"? When they're manually "on" the high beams work like old school.Weird.
At least you guys Auto High beam works lol
Mines are not “Auto” at all
It seems they only available with the Advanced Safety Package... so it depends on what trim you have.
I have the ACC so Advanced Safety Group is definitely equipped.
Welp... then you have an issue. I set my headlight to Auto and then just push the stalk forward to get the message they aer enabled. They only really turn on when I'm driving down rather dark streets...
UH THIS IS TOXIC
I ONLY HAD THIS BRAND NEW TRUCK FOR 2 DAYS
Annoying, perhaps, and you shouldn't have to deal with these things on an expensive new vehicle, but "toxic"? Really? Definitely annoying, but hardly toxic - a genuine "first world problem". Bugs happen, especially to a new vehicle with as much technology packed into it as these new Rams have. Maybe your sensor is bad, or the windshield is optically distorting the light entering the sensor, or maybe you need a software update or firmware reflash.
