If you are going to use the numbers below to order parts, double check them as things can change over time, so it's going to be up to you to verify you're getting the correct part when ordering. If you find a mistake please let me know so I can correct it.
5th Gen 1500 Handle and Cap Part Numbers
These should work on any of the 2019 and newer 5th gen 1500 trucks. Harnesses are going to be more specific based on your options, or you can just add the 2 wires and plugs to your existing stuff and save a good bit of money.
| COLOR | BODY COLOR HANDLE, L & R | BODY COLOR/CHROME HANDLE L & R | HANDLE CAP, LEFT | HANDLE CAP, RIGHT |
| Bright White | 6CV64GW7AD | 6CV361W7AD | 6CV50GW7AC | 6CV52GW7AB |
| Ivory White | 6CV64KGZAD | 6CV361WDAD | 6CV50JWDAC | 6CV52JWDAB |
| Diamond Black Crystal | 6CV64KXJAD | 6CV361XJAD | 6CV50KXJAC | 6CV52KXJAB |
| Maximum Steel Metallic | 6CV64KARAD | 6CV361ARAD | 6CV50KARAC | 6CV52KARAB |
| Granite Crystal Metallic | 6CV64LAUAD | 6CV361AUAD | 6CV50LAUAC | 6CV52LAUAB |
| Billet Silver Metallic | 6CV64JSCAD | 6CV361SCAD | 6CV50JSCAC | 6CV52JSCAB |
| Patriot Blue Pearl | 6CV64RPXAD | 6CV361PXAD | 6CV50RPXAC | 6CV52RPXAB |
| Blue Streak Pearl | 6CV64KCLAD | 6CV361CLAD | 6CV50KCLAC | 6CV52KCLAB |
| Flame Red | 6CV64PR4AD | 6CV361R4AD | 6CV50PR4AC | 6CV52PR4AB |
| Olive Green | 6CV64KFPAD | 6CV361FPAD | 6CV50KFPAC | 6CV52KFPAB |
Replacement Clips for the 1500 door panels
Door Interior Trim Panel Retainer (Yellow):  6510747AA
Door Interior Trim Panel Retainer (White):  6510359AA
HD Part Numbers
Thank you to
@01Time for providing the more comprehensive list below for the HD trucks than I had originally posted.
| COLOR | BODY COLOR, FRONT LEFT | BODY COLOR, FRONT RIGHT | BODY COLOR, REAR LEFT | BODY COLOR, REAR RIGHT | BODY COLOR/CHROME, FRONT LEFT | BODY COLOR/CHROME, FRONT RIGHT | BODY COLOR/CHROME, REAR LEFT | BODY COLOR/CHROME, REAR RIGHT |
| BILLET SILVER METALLIC | 1UJ81JSCAI | 1UJ86JSCAI | 1GH19JSCAF | 1GH18JSCAF | 6NV571SCAD | 6NV561SCAC | 6NV591SCAC | 6NV581SCAC |
| BLACK FOREST GREEN PEARL | 1UJ81KGZAI | 1UJ86KGZAI | 1GH19KGZAF | 1GH18KGZAF | 6NV571GZAD | 6NV561GZAC | 6NV591GZAC | 6NV581GZAC |
| BLUE STREAK PEARL | 1UJ81KCLAI | 1UJ86KCLAI | 1GH19KCLAF | 1GH18KCLAF | 6NV571CLAD | 6NV561CLAC | 6NV591CLAC | 6NV581CLAC |
| BRIGHT SILVER METALLIC | 1UJ81WS2AI | 1UJ86WS2AI | 1GH19WS2AF | 1GH18WS2AF | 6NV571S2AD | 6NV561S2AC | 6NV591S2AC | 6NV581S2AC |
| BRIGHT WHITE | 1UJ81GW7AI | 1UJ86GW7AI | 1GH19GW7AF | 1GH18GW7AF | 6NV571W7AD | 6NV561W7AC | 6NV591W7AC | 6NV581W7AC |
| BRILLIANT BLACK PEARL | 1UJ81AXRAI | 1UJ86AXRAI | 1GH19AXRAF | 1GH18AXRAF | 6NV571XRAD | 6NV561XRAC | 6NV591XRAC | 6NV581XRAC |
| DELMONICO RED | 1UJ81NRVAI | 1UJ86NRVAI | 1GH19NRVAF | 1GH18NRVAF | 6NV571RVAD | 6NV561RVAC | 6NV591RVAC | 6NV581RVAC |
| DIAMOND BLACK CRYSTAL PEARL | 1UJ81KXJAI | 1UJ86KXJAI | 1GH19KXJAF | 1GH18KXJAF | 6NV571XJAD | 6NV561XJAC | 6NV591XJAC | 6NV581XJAC |
| FLAME RED | 1UJ81PR4AI | 1UJ86PR4AI | 1GH19PR4AF | 1GH18PR4AF | 6NV571R4AD | 6NV561R4AC | 6NV591R4AC | 6NV581R4AC |
| GRANITE CRYSTAL METALLIC | 1UJ81LAUAI | 1UJ86LAUAI | 1GH19LAUAF | 1GH18LAUAF | 6NV571AUAD | 6NV561AUAC | 6NV591AUAC | 6NV581AUAC |
| MAXIMUM STEEL METALLIC | 1UJ81KARAI | 1UJ86KARAI | 1GH19KARAF | 1GH18KARAF | 6NV571ARAD | 6NV561ARAC | 6NV591ARAC | 6NV581ARAC |
| PATRIOT BLUE PEARL | 1UJ81RPXAI | 1UJ86RPXAI | 1GH19RPXAF | 1GH18RPXAF | 6NV571PXAD | 6NV561PXAC | 6NV591PXAC | 6NV581PXAC |
| PEARL WHITE | 1UJ81PWQAI | 1UJ86PWQAI | 1GH19PWQAF | 1GH18PWQAF | 6NV571WQAD | 6NV561WQAC | 6NV591WQAC | 6NV581WQAC |
| TRUE BLUE PEARL | 1UJ81KBUAI | 1UJ86KBUAI | 1GH19KBUAF | 1GH18KBUAF | 6NV571BUAD | 6NV561BUAC | 6NV591BUAC | 6NV581BUAC |
| WALNUT BROWN METALLIC | 1UJ81RUWAI | 1UJ86RUWAI | 1GH19RUWAF | 1GH18RUWAF | 6NV571UWAD | 6NV561UWAC | 6NV591UWAC | 6NV581UWAC |
| HYDRO BLUE METALLIC |  |  | 1GH19MBJAF | 1GH18MBJAF | 6NV571BJAD | 6NV561BJAC |  |  |
| OLIVE GREEN METALLIC |  |  | 1GH19KFPAF | 1GH18KFPAF | 6NV571FPAD | 6NV561FPAC |  |  |
The following is a breakdown of the parts you will need to assemble your own 2-wire harnesses for the doors, as well as the rear antenna. All of the connectors and terminals can be found at Mouser or Digikey, except for the Yazaki stuff.
Rear Antenna Wiring Parts
22AWG wire (2 colors to make it easy)
Heat shrink tubing (recommended)
Braided wire sleeve (recommended)
Rear PE Antenna: 52112204AA or 56046957AA should work in this location
2019 & 2020 Rear Fascia Connector Terminals: TE Connectivity 1241380-1
2019 & 2020 Rear Fascia Connector Wire Seals: TE Connectivity 828904-1
2021 Rear Fascia Connector Terminals:
2021 Rear Fascia Connector Wire Seals:
2019+ Rear Antenna Connector Shell: TE Connectivity 1-1438608-5
2019+ Rear Antenna Connector Shell Terminals: TE Connectivity 1355717-1
2019+ Wire Seals for Antenna Terminals: TE Connectivity 963530-1
Door Handle Wiring Parts
18AWG wire (2 colors to make it easy)
Door Connector Terminals: Aptiv 10762775
Door Handle Connector Shell: Yazaki 7283-6079-30
Door Handle Connector Shell Terminals: Yazaki 7116-4720-02
Yazaki parts are hard to find without ordering minimum quantities. One option is to call SMD Inc, and see if they’ll send you free samples (2 connectors, 4 terminals).
