5 Inch to 8.4 Inch Upgrade
I was able to resolve the issue with USPS, got the package, apparently someone had the same number for their house but what I don’t get is how can they get confused with different street names? Anyways I tried to install the 8.4 with Navi and tried to use Alpha OBD and no luck, the screen didn’t even come on, but my fan stayed on every time I turned the ignition to on, I must be doing something wrong, help, lol
Did you figure out the issue with your HVAC fan? I installed a 8.6 that is loaded to replaced my 5" basic radio with manual HVAC system . Got the unit to fire up, installed the code, but the fan and all the HVAC is inop. Same problem you are having. Question is, do I need to install the HVAC module above the glove box on the side of the dash?
So just wanted to give you guys the updated pictures after I received the new bezel today. Everything works perfectly. Next step I'm going to ask the dealership if they can load the app to control the heated steering wheel from the screen. Let me know what you guys think.
Where did you buy the upgraded screen? I am trying to do the same for mine and looking to find a place that won't break the bank
Where is the best place to buy the screen for a cheap price?
Yes, it was just a programming issue, Jimmy 07, pointed me in the right direction, I downloaded the Alfa obd app, I am able to use auto climate on a single zone
SO I know I'm late to the party on this discussion but I have tried registering on this site for quite some time and finally got my account confirmed!! I have read almost all 18 pages of this thread and I still have questions. I want to upgrade my 5" radio but don't really want to spend the $1,699 for the 8.4" from informant. I have the 5th gen bighorn with the single zone climate. What can I do for a radio upgrade without spending the 1700? I keep finding radios on ebay with dual zone but after a lot of research they are not plug and play ( I could be wrong). I had a audio place tell me I could this with a sony touch screen for around 750 but I'm iffy that its going to be that easy. I dont think they understood the difference between classic and DT body styles. I know this seems like a beating a dead horse seeing how old this thread is but any insight would be much appreciated
If you want to upgrade from a 5” to an 8.4” screen, there are a couple of things to consider, do you want nav? Or no nav. There is the uconnect 4 format, this is only for 19-21 models, it’s possible to upgrade to uconnect 5, but you will have to get all the parts for it, because a uconnect 4 screen will not work with a uconnect 5 radio module, but take it it one step at a time. I currently am running the 8.4” uconnect 4 system, I was very fortunate to find the whole setup with the bezel and the module. You should not have any issues finding a full setup. So your concerned about dual climate zone auto climate, I bought a setup with the dual zone hvac controls, I am running my setup with single zone auto climate, in order to get this to work I had to buy the auto climate harness and the sensors, you can get that on Infotainment. Com, if and when you do get this, programming is not that hard. I learned how to do everything from this forum. Also type in jimmy 07, he is very knowledgeable about the 5th gen Rams, if you need help with part#’s let me know
Yes, you will need to use AlfaOBD to change Cabin Net: DCSD Display Screen Module to “Enabled”.
Heya Jimmy
I'm curious,
I've installed my new 8.4 in a 2019 Tradesman with manual climate controls and 7 speed fan. The unit I put in is a model ending in 4AC that has the ability for auto climate. I personally could care less about the autoclimate since there are manual controls. However, with the install the climate controls are stuck on high defrost. Does the setting above resolve that issue or do I have to install all of the wiring and sensors to support ATC in order for the manual controls to start working?
For what its worth, I sourced an entire bezel complete with the radio and HVAC control module.
Thanks in advance!
I’m upgrading my 2020 Ram 2500 from a non-xm 5” radio to a non nav 8.4. From what I’m reading, all 2020 and up 2500s come wired for SAT radio regardless of trim level or radio. My current truck has a red plug, blue plug, grey plug and white plug. Do I need a conversion harness to implement SAT radio?
And you retained the steering wheel controls? How did you get the truck to recognize the new radio?
So just some background on what kind of truck I have. I have a base model tradesman with the upgraded seat package. Nothing fancy. I already replaced the original steering wheel with one out of a rebal. That was a direct swap and all the buttons work. The only thing I havent tried is the heat function. So i received the 8.4 yesterday and completed the installation. Everything was plug and play. The only thing that wasnt plug and play is the temperature controls. My tradesman doesnt have dual climate and the one I bought did. So I used my original cluster with the screen until my new one comes in. So besides that everything works. Just make sure if your buying one second hand that you get the VIN number from the truck it came off originally. You will need that along with the serial number on the Navi to get the anitheft code from the dealership. I'll post pics once my new temp cluster comes in. Hope this helps some others!
After the install of the new one how did you get the truck to recognize the radio? Mines not recognizing my steering wheel controls. Is there like a special way you did after hookup
It’s a Tradesman. I plugged the radio in and it worked no issue. I do need the cable to obtain sat radio.
I don’t have steering wheel controls on the Tradesman
Don’t you still have the phone controls on the front? When you installed I was told who I bought the kit from he believed there was a sequence of unplugging the battery then leaving the truck in the on position for so long etc. did you do that?
I’ll check and see for you.
So you bought a 8.4 bezel with single zone?
I am also trying to upgrade from a 5 inch. Non nav one zone. 2019 ram rebel. Really struggling to find something that isn't $1700.
