Any Rebels out there with the dealer installed 1"Mopar lift?
I must be mistaken, but I thought the 2” Mopar lift couldn’t be used with previous gen Rebel because of the air suspension.
After seeing the Rebel Smoke concept with the 2” Mopar lift (and 35’s), I thought perhaps it can used on the Rebel with standard suspension.
EDIT: After doing some more research it appears that the Mopar kit is still not compatible with the new rebels.
You only need to level a coil suspension Rebel to fit 35's. To properly level a Rebel with less than 1/4" rake, 2.5" top of strut spacer will do the job, in my experience. But because the Rebel already has longer struts you need UCA's to handle the new balljoint angles.
Ok so my question....how do you know if your Rebel has the 1" lift or not? Looking at my window sticker and see nothing but the level 2 equipment group.
All have the 1" standard with the Rebel trim.
ok thats what I was thinking. seems like only the ones with the air do not have it then?
I think the air does have it. It just adds even more lift with the suspension fully raised than the coil springs.
