ChadAllen
 - Mar 19, 2022
Greetings everyone! My 2019 5.7 4wd recently started that infamous ticking. I'm trying to narrow down the source before I commit to tearing things apart. The only Ram dealer in town is a piece of work and I'm out of warranty (71k miles) so I'll be doing it myself. Any help with diagnosis would be greatly appreciated.
The tick is faint. I don't hear it while I am driving, or even sitting at a stop sign with the windows down. Only hear it when I'm walking around the front of the truck or at a drive thru where the engine echoes off the wall. It doesn't get louder or quieter at any point. It doesn't go away as the engine warms. But it's also not louder at start up. I've had a couple cars in my life with bad lifters and the ticking was always louder on initial startup until those initial rpms drop to idle as the oil first starts circulating. If anything, the tick doesn't start until that initial sequence is done and the rpm drops.
I took a stethoscope to it and I'm having a hell of a time pinpointing it. Stuck in a gap under the intake manifold Same for valve covers on both sides, heads and exhaust manifolds. Never had a point where I touched the stethoscope and said "whoa, there it is." I could hear it faintly everywhere.
No codes. Idle is smooth. Drives fine. Normal acceleration.
I change the oil when recommended, use Mopar filters and royal purple full synthetic. I know the lifters don't like idling, so I don't do that except at red lights (of course). Did everything right, so if it's the lifters I'm gonna be.....well, you know.
Any other tricks I can try? My brain is telling me maybe there is a crack in the exhaust manifold that is amplifying an otherwise normal internal tick, but I don't know. The engine is too hot right now to pull off the heat shields to check, and it's about to start pouring rain. Just thought I'd ask for help brainstorming while I wait.
Truly appreciate any help.
