ChadAllen
- Mar 19, 2022
UPDATE: I'm currently in a holding pattern. I ordered parts from Mopar, but still waiting for them to arrive. In the meantime, I've come up with my plan. I sent an oil sample off to Blackstone. If that sample comes back with lots of metal in the oil, then I am going to return the parts and sell this truck. If the analysis comes back clean, THEN I'll pull the heads and replace those lifters. There's no point, in my mind, of changing the cam and lifters if metal from the cam is already circulating through the engine. That metal will never be completely removed and will most definitely destroy rod bearings at some point. Went through this with my wife's Santa Fe. They left metal in the block from the machining process. The dealer did an oil flush, but there's no way to be sure ALL the metal was retrieved. Her engine completely seized a few thousand miles later. She ended up needing a new engine.
I'm not taking that risk in a vehicle that tows a camper all the time...... cause my luck THAT will be when the engine fails.
I will keep you all posted. Thanks again for everything
