First off, when the parts arrived the rear part of the kit was very well boxed and arrived safely. The drop spindles came in a separate box that was mangled to hell and back. It was also missing the hardware kit that comes with it.
Now began the fun. For reference I repair welders in a tire shop that does lift kits quite often as well as various suspension repairs. So, they have a good idea of what they are doing.
First things first. We put the truck on a two-post lift. We began in the front since that would be the easiest starting point. The wheels came off and we removed the factory spindles (knuckles). We installed one drop spindle and tested it for fit with the factory 20" wheel. The lower ball joint was too long. The instructions do cover this so we cut the ball joint down to fit. The factory 20 will just barely fit. Too close for my taste but it would probably be fine for someone not as OCD as I am.
We ended up putting the stock knuckle back on and I drove her home that night. I contacted Belltech and discussed it with them as well as sent pictures.
To solve this issue I ended up just buying the wheels and tires I had planned to get later down the road and installed them. With 22" wheels there was much more clearance as to be expected.
BT then sent us the missing hardware from the spindle kit and we installed the spindles and began the back end of the kit.
