Halfpint81
Hey is anyone running 285/65r20 with a 4 inch lift? Just wondering how it looks
Thank you I’ll have a look@Redz72 is close on lift and runs tire size.
Thank you for the pictures, your truck looks really good. You leveled your truck? The reason for the tire size question on a 4 inch lift wondering how they would look, I have 35 and I’m go ding them heavy so wonder g if a smaller tire on the lift would look funnyView attachment 181945
Thanks @Ready Go
285/65r20 Yokohama Geolander AT G015
2” front RC struts
1” Motofab rear spacer
Tires are 34.8x11.6x20.
Thanks man. Yes my truck is leveled. 2” front RC struts and 1” Morofab rear. I have 1.5” rear coils to install when I get the time.Thank you for the pictures, your truck looks really good. You leveled your truck? The reason for the tire size question on a 4 inch lift wondering how they would look, I have 35 and I’m go ding them heavy so wonder g if a smaller tire on the lift would look funny
I have 295/65r20 K02s and they are 70 lbs each and noticed 285/65r20 K02s are 10 pounds lighter so thinking of the switch to see if the truck runs a little nicer but wanted to make sure the smaller sized doesn’t look dumb on a 4 inch liftThanks man. Yes my truck is leveled. 2” front RC struts and 1” Morofab rear. I have 1.5” rear coils to install when I get the time.
The G015’s metric 285/65r20’s measure 34.8” which is actually larger than some flotation 35x12.5r20 measurements. I was also concerned (slightly) about weight which is why I went with the Yoko’s. They weight ~59lbs which is on the lighter side of ~35” tires.
Your truck looks great man. IMO, I’d go for the lighter tire. 10lbs per tire is quite a bit. Especially for~ 1/2” difference. I say go for it.
Thank you, yeah in those pictures which I took yesterday I’m running 295/65r20 K02s I don’t think 34s will look that bad in the end and like you said a lot lighterYour truck looks great man. IMO, I’d go for the lighter tire. 10lbs per tire is quite a bit. Especially for~ 1/2” difference. I say go for it.
