Tire size
Redz72
Langhorne, PA
Thanks @Ready Go
285/65r20 Yokohama Geolander AT G015
2” front RC struts
1” Motofab rear spacer
Tires are 34.8x11.6x20.
Halfpint81
Alberta
Thanks @Ready Go
2” front RC struts
Thank you for the pictures, your truck looks really good. You leveled your truck? The reason for the tire size question on a 4 inch lift wondering how they would look, I have 35 and I’m go ding them heavy so wonder g if a smaller tire on the lift would look funny
Redz72
Langhorne, PA
Thanks man. Yes my truck is leveled. 2” front RC struts and 1” Morofab rear. I have 1.5” rear coils to install when I get the time.
The G015’s metric 285/65r20’s measure 34.8” which is actually larger than some flotation 35x12.5r20 measurements. I was also concerned (slightly) about weight which is why I went with the Yoko’s. They weight ~59lbs which is on the lighter side of ~35” tires.
Halfpint81
Alberta
I have 295/65r20 K02s and they are 70 lbs each and noticed 285/65r20 K02s are 10 pounds lighter so thinking of the switch to see if the truck runs a little nicer but wanted to make sure the smaller sized doesn’t look dumb on a 4 inch lift
Halfpint81
Alberta
Your truck looks great man. IMO, I’d go for the lighter tire. 10lbs per tire is quite a bit. Especially for~ 1/2” difference. I say go for it.
Thank you, yeah in those pictures which I took yesterday I’m running 295/65r20 K02s I don’t think 34s will look that bad in the end and like you said a lot lighter
