OEM Halogen Headlights Conversion to OEM LED Headlights 2019-2023
RAMTUNINGPOLAND
Hello everyone.
I decided to change the headlights in my 2022 DODGE RAM car from normal to original LED ones from the Laramie version.
I encountered the first problem, a different plugin.
I bought the appropriate plug and started changing the pins, now the LED parking lights, high beams and high beams work. Basically, the only problem I have is with the turn signal, it comes on for half a second and immediately goes off, it doesn't blink.
I have a second car that originally had the same headlights installed, but it turns out it has 3 more pins. One is the LED daytime running light, I dealt with it. I have two cables left that I don't know where to connect, I suspect that if I do it right, the turn signal will work properly and my conversion will be 100% successful. Do we have an electrician to help me?
I don't know where to connect PIN NR:
5D5030.35WH/OGLIN LIGHTING
12L5520.35BG/OGRIGHT FRONT LIGHTING FAULT SENSE
The brown cable in my photo is the LED daylight. When I plug them into the fuse box, they work.
Blue is PIN number 5 from the plug
I know it can be done, I just haven't learned how to do it yet.
If anyone can help me and has done something like this, I will be very grateful.
I'm from Europe and there aren't many people here who can do it.
Just buy this harness for $200USD and be done with it.
Thank you for your reply,I changed the plug and set the pins as needed, I added one only for LED daytime running lights. Then coding solved all the problems. So you don't need any $200 adapters, just buy two $20 plugs, put the pins in the right order and program everything.
Can you message me the correct pin locations? And where you got the plugs please. Looking to do the same
Thanks
How did you dealt with the fault Sense wire?
How did you Programmed it?
Could you please help me with the process you went thru? I recently swapped all of mine over and my front turn signals are having the exact same problem as yours. Thanks.
Hello everyone.
The white one is PIN number 12 from the plug.View attachment 181374
I've never seen a 2022 DODGE RAM CAR. ;)
Hi, Just wanted to share my ordeal in converting halogens to led lamps, first i want to thank user:
RAMTUNINGPOLAND
who shared some useful tips and i think if i share mine, it can help someone also.
At first: I bought chinese version of Laramie lamps, they look identical. But if you investigate the 16 PIN socket. You can notice that there are some pins missing (Relay control, LIN, Fault sense ). So what i did was - i purchased 12 pin and 16 pin Molex connetors from Aliexpress (both male and female) and added some wires.
I connected old halogen 12 pin connector wires directly to the corresponding pins of new 16 pin connector, and added an extra wire (PIN6 - L117, L118) and wired it to the fusebox under fuse F38.
After that i did some modifications under BCM using alfaOBD -> i changed four settings only - LED FRONT TURN;HIGH BEAM;LOW BEAM;LED FRONT PARK/MARKER. I did not made any changes in "turn signal diagnostics". So far everything has worked perfectly. DRL settings are still the same as were before.
