RAMTUNINGPOLAND
- Mar 9, 2024
Hello everyone.
I decided to change the headlights in my 2022 DODGE RAM car from normal to original LED ones from the Laramie version.
I encountered the first problem, a different plugin.
I bought the appropriate plug and started changing the pins, now the LED parking lights, high beams and high beams work. Basically, the only problem I have is with the turn signal, it comes on for half a second and immediately goes off, it doesn't blink.
I have a second car that originally had the same headlights installed, but it turns out it has 3 more pins. One is the LED daytime running light, I dealt with it. I have two cables left that I don't know where to connect, I suspect that if I do it right, the turn signal will work properly and my conversion will be 100% successful. Do we have an electrician to help me?
I don't know where to connect PIN NR:
The brown cable in my photo is the LED daylight. When I plug them into the fuse box, they work.
Blue is PIN number 5 from the plug
The white one is PIN number 12 from the plug.
I know it can be done, I just haven't learned how to do it yet.
If anyone can help me and has done something like this, I will be very grateful.
I'm from Europe and there aren't many people here who can do it.
5 | D503 | 0.35 | WH/OG | LIN LIGHTING |
12 | L552 | 0.35 | BG/OG | RIGHT FRONT LIGHTING FAULT SENSE |
