Robman700
- Sep 23, 2021
Talk to me about your wheel and tire combo
Wheels are fuel covert, 20x10 and rubber is Yokohama mt’s 37x12.50
Nice! You happen to do a write up?
Yup this is the exact write up I got how to do mine but a little different as I have the 22 with the UC5.![]()
2023+ digital cluster swap (COMPLETE WRITE UP)
First thing to know, mileage correction can’t be done via AlfaOBD yet but I was told it’s being worked on. With that out of the way, let’s look at the stages. Stage 1 (cluster only): To do this at its most basic level, you only need the cluster and a custom adapter harness from Jimmy07. To...www.ram-trx.com
holy smokes!Got the digital dash cluster installed yesterday!! Sorry for the bad picture (need to clean lense) but super easy install just to get it working now to get the tiles and Ram Maps working a little more involved at this point.
Did you need to swap your radio and BCM in addition to the cluster?Yup this is the exact write up I got how to do mine but a little different as I have the 22 with the UC5.
I haven’t the tiles don’t work unless you switch to a 23 BCM. I did not switch my radio either.Did you need to swap your radio and BCM in addition to the cluster?
I have the same yoko's in a 35. Not sure I'll go quite as aggressive next time, but it's a great off road tire.Wheels are fuel covert, 20x10 and rubber is Yokohama mt’s 37x12.50
TDS Brotha TDS!Nice truck (lose the TRUMP flag though)
Interesting to see if any issues using a 23 Gal pump. I've seen you NEED the 26+ Gal pump.99% of my parts showed up my sisters that I ordered end of Jan… joined the 33 gallon tank again. Swap wasn’t bad I did manage to break the plastic retainer clip on the stock setup comparing fuel pumps. Turns out the pump I bought off a totaled Ram w/ 14k miles had a 23 gallon tank and not a 26 gallon that was told d’oh. Of course the plastic retainer is a different size so there was no going back so the 23 gallon pump went it didn’t want truck sitting and didn’t want to shell out the ridiculous price Mopar wants for a 33 pump vs 23g $150-$550. Pumps the same size between the two besides the floater being slightly longer.
Loving the suede upgrade!!Did a lot this weekend! I got my topographical vinyl wrap done over all the faux wood (all four doors, back of the center console, and top of Infotainment system). Also, got the suede put in over the awful gold/tan color (sides of the center console and side of the infotainment system). Very time consuming but to me looks so much better now.
Thank you!! Here is the link it’s a German company called Indivitara I got it in just under two weeks through Germany Amazon but it’s the best premium suede adhesive that I could find from my search.Loving the suede upgrade!!![]()
Got a link to the material?
