Hemi Front Lift | Rear Lift | Front Travel | Rear Travel | Shock Diameter | Tire Fitment |
1.5″ | 1″ | 8″ | 12″ | 2.0″ | 35″ x 12.5 |
This is the deal breaker for me. Plus, yeah.. the 35s fit but they look super stuffed. The Fox 2.5 at least claims 3" lift.. Back to square one.Wait so the carli 2.0 commuter system doesn't lift the truck at all?
It lifts a regular 1500 4x4. Rebels are different. Everything you need to know is on Carli's website.This is the deal breaker for me. Plus, yeah.. the 35s fit but they look super stuffed. The Fox 2.5 at least claims 3" lift.. Back to square one.
Been through it many times. There's "regular 1500 4x4," then there are non-Rebel 4x4s with the Off Road Package that make them, suspension wise, measure out the same as the Rebel. My Built to Serve has the ORP, so I'd get Rebel numbers... and I'm after taller for the $$It lifts a regular 1500 4x4. Rebels are different. Everything you need to know is on Carli's website.
give it some time for it to settle and then measure again.I just installed this system on my truck and this is the lift measurements I got on my rebel
I always hear this about "time to settle" but what changes?give it some time for it to settle and then measure again.
also it'd be more accurate if you measure on flat surface.
How much time do you guys think like 10k miles? Also what psi you guys running on 35s?give it some time for it to settle and then measure again.
sometimes the weight of the truck will push the springs down more. i dont know why, and i don't know how. i just know it happens. not drastic change, but a small change.I always hear this about "time to settle" but what changes?
Is it the new springs' "break-in" period?
And since I've opened this can-o-worms:
Springs are always referred to as "Lbs/Inch" but which inch? The first one from static with a particular load or the second, maybe the third? In compression or expansion?
PS - with excellent way in which El_PWR presented his data, I'm going to guess that while his pictures were taken on his driveway I bet that his measurements were taken on a flat surface.
nah you don't need that many miles. Just a long lap around the block or even commute should do the trick. I was under the impression that you did it yourself at home that's why I made that comment. If you had it done at the shop then the springs should settle already between the drive from shop to home.How much time do you guys think like 10k miles? Also what psi you guys running on 35s?
The reason that your suspension sits higher after you had it off the ground is because it is bound up. When it was off of the ground, the suspension drooped. When you set it down the tires are trying to "spread out" due to the suspensions geometry. Just have a look at the tires side wall once it's back on the ground, before it is rolled out.sometimes the weight of the truck will push the springs down more. i dont know why, and i don't know how. i just know it happens. not drastic change, but a small change.
It's like when you jack up the front of the truck, then put it back down. It sits higher until you turn the steering wheels left and right and the springs compresses to "settle" a bit.
I understand that this is just the way that springs are referred to as an industry standard but...The inch in spring rates (lb/in) refers to the amount it of weight it takes to compress the spring an inch. It is an universal way of calculating spring rate and not vehicle or load specific. It doesn't change before or after the springs are settled. Say, for instance, for 600lb/ft spring rate, it takes 600lb to compress the spring 1in. If you stack 1200lb on it, it compresses 2". Spring rate is still at 600lb/in.
How does it ride?I just installed this system on my truck and this is the lift measurements I got on my rebel
yes i should've clarify it more clearly. i was at the end of my part time night shift and the next guy was coming in when I posted the comment. But you nailed it perfectly.The reason that your suspension sits higher after you had it off the ground is because it is bound up. When it was off of the ground, the suspension drooped. When you set it down the tires are trying to "spread out" due to the suspensions geometry. Just have a look at the tires side wall once it's back on the ground, before it is rolled out.
That's why every wheel alignment rack has "Alignment Plates" that can slide out in all directions, and allow the suspension to relax.
At home rolling the vehicle forward or backward just one tire revolution will allow that to settle out.
I feel that you already knew that, but I wanted to clarify for others because of the way it I interpreted your previous post.
Here is where I am confused:
If it took 600 Lbs. to compress the spring one inch, then surely it will take more than just another 600 Lbs. to compress the next inch. No?
And are we talking the about compressing the spring from a completely relaxed state? Like before it is installed?
Or are we talking about compressing it one inch from static ride height, whist it is supporting the weight of the vehicle?
I know all about "Progressively Wound" coils but I feel that even coils that are NOT progressively wound still have spring rates that are no where near linear when they compress and get closer to or farther from their point of coil bind (fully compressed-end of stroke).
I've heard of but never researched shock & spring dyno plots.
I know it's a thing but I fear getting over my head in the complexity.Lol
