Carli 2.0 commuter system
Where would one find the Bilstein kit that you mention?
I tow to full capacity a few times a year so I have Timber Grove air bags in the rear, but I am dissatisfied with unladen ride quality and dislike the appearance of the added rake that the minimum air pressure in the bags results in.
I do mess around off road relatively frequently and would really like to put a set of 35" MT's on my Rebel, just not sure how to get her to do everything....
Amazon
I just installed this system on my truck and this is the lift measurements I got on my rebel
Man I didn’t get anything near that! So much so that I’ve been debating adding a 1” spacer or body lift to make up the difference…
I got 38.25” front 40” rear with 285/65/R20 KO2s.
Truck looks great! 👍🏼
Looks great! Two questions: 1) What kind of hit on MPG?, and, 2) Is there any noticeable power decrease [felt...]?
Man, that does seem off.
My Laramie G/T stock was 36.875" front and 38.625" rear with OEM 275/55R20s (31.9").
I swapped in Eibach Pro-Truck struts on Clip #2 (0.625" lift) with ORP (1.0" lift) front springs and now am at 38.5" front and 38.625" rear with OEM 275/55R20s (31.9").
I'm 0.25" higher than you in front with a tire that is 2.6" shorter (1.3" less lift) than yours!!
Your numbers are ~1.3" higher than my stock OEM numbers..which correlate to your tires being 1.3" lift compared to my OEM tires...I have to assume you have NO level/lift etc done?? (I felt your post suggested you did..Carli Commuter w/ Rebel HD rear springs??)
No man you are spot on. I have the Carli Commuter for the Rebel (my truck is a Laramie with ORG) the Rebel HD springs and 285/65/R20s. I’m currently at approx 38.25” front and 40.25” rear. I can sorta understand the rear as I’m running the topper, decked drawers and recovery gear. But I don’t understand the front and definitely not happy with it. So much so that I reached out to the original manufacture regarding it.
I hear ya, and agree..the front seems way off!
Given your suspension setup, I'd expect you should be at about 40"+ front just from the Carli's.
Then add the 285/65R20, which should be about 34.5" tall, and I'd think you'd be another 1.3" higher at about 40.8" front and 41.3" rear.
My Laramie was 36.875" F and 38.625" rear stock..your Laramie ORP should have 1" from the ORPs and 0.5" from 33s..so you should have been about 38.375" F and 40.125" rear stock (using mine as a base..but these trucks vary a lot).
Carli Commuters supposedly are ~2.25-2.5" front lift on a non-ORP like mine..and ~1.25-1.5" on an ORP like yours.
My coffee isn't fully on board yet this morning, but adding this way, your L-ORP should be ~40.625" F and ~41.25" R.
Either your Laramie wasn't an ORP, or doesn't actually have the Carli & HDs installed or doesn't have 285/65s installed or the Front Carli's are way off adjustment or ???...I just can't figure it out...I can understand your frustration or disappointment, something's up!!🤔
Believe me I'm right there with ya. I can tell you for sure that my truck definitely has the ORP, or at least has all of the additional components (appropriate skid plates, rear axel lock, hill decent, etc.).
Regardless, the suspension was replaced with the carli commuter which should have negated whatever suspension was on it before. The tires are definitely 285/65/R20s, unless the sidewall is incorrect on all four of them...
I do know BFG KO2's run slightly smaller circumference wise, but not drastically.
I reached out to CJC Offroad; where I bought the kit; and they advised to adjust the collar in order to preload the coil over by about 1/2". I haven't done this yet as the kit was supposed to come set at the appropriate height from the factory and Carli advises against adjusting the collar any more as this could cause the spring to bind. Currently trying to research if I am able to tell based on where the collar is currently adjusted if I have room to adjust the preload more or not.
Based on my measurements, I feel like I ended up pretty much exactly where I was stock prior to the suspension/tire modifications. My truck doesn't sit horribly, but definitely not what I was going for, and I did a TON of research before pulling the trigger...
Those front struts HAVE to be off. Possibly they weren't setup correctly by Carli..someone missed something.
It’s a planted and cushiony feeling, I took it on a road trip from northern Nevada to California coast and I was very impressed. I would say it’s better than stock. The stock suspension always felt almost too soft and sloppy if that makes sense. Lowering the psi to 40 made it even more comfortable. I did loose mpg with the 35s and level. Previously I’d at best get around 23 highway at 80mph since I live at 5500 ft of elevation and now I get around 20 at 80 mph which is still pretty good. I will be doing some off roading and trailering here in the next months and update on the ride quality.
Little update, this suspension likes to be ridden hard and handles well. I found myself driving a lot faster and confident on dirt roads. Usually I would be going 40-45 max and it would feel like I was losing control and now I’m hitting 60 and not knowing until I look at the speed. It has become a very comfy truck. While trailering 10,000 lbs the truck does squat which I expected since it’s a soft truck I will probably end up getting air bags to help with the squat.
I recently installed the Carli spec commuter system with the HD rear springs on my ‘23 Rebel and gained approx. 2 3/4” front lift and 2 1/4” rear lift (Including tires). Tires are 35 12.5s Toyo A/T IIIs on stock wheels with 1.25” Bora wheel spacers. I still have a rake of 1.5”, which is what I was after for towing, etc. (original rake was 2”) I feel like the ride quality around town is similar to stock, but with larger potholes and speed bumps I see a significant improvement. I think the higher ride height and larger tires give the truck a dramatically better look over stock.
View attachment 187411View attachment 187413
This is the setup I'm looking for...any rubbing?
I put the Carli Commuters on my 2025 Laramie with the ORP. The ride got a lot smoother on the rough rural roads around here. They are not as firm as the ORP shocks, but the truck still handles great while driving on curvy canyon roads. I got about 1 1/2" lift in front and 1" in back with the HD coils. The ORP coils were probably compressed a 1/2" from the camper shell. Now it's at 40" in front and 40 1/2" in back with 33 1/2" tires. I went with Core 4x4 UCAs because I was told by CJC Offroad that Carli UCAs would not fit with 0 offset wheels. Overall, I am very happy with the upgrade and highly recommend the setup. Before...
After...
Front Before and After...
Rear Before and After...
After...
View attachment 199117View attachment 199118
View attachment 199119View attachment 199120
Looks good! Let me know how you like the Core UCA'S.
I haven't done any real off-roading unless you count our dirt road. I do pop off and on the pavement quite a bit on single-lane roads to let a car pass. Everything is really solid and quiet, and the alignment is perfect. My local mechanic, who is a Rubicon off-roader, likes how adjustable the UCAs are. I did go with FK Rod Ends.
Carli Commuter is top notch stuff! Especially the Carli spec 2.5 coilovers. Any members looking to get into this kit, feel free to reach out to me be it on the forum or my email [email protected] and ill get you taken care of the right way the first time! We are one of the largest Carli dealers and offer wallet relief for forum members.
After...
What wheel specs are these??
Can you run these with the factory UCA's?
Fuel Rebel 6 20x9 +1mm offset
Toyo Open Country A/T III LT285/60R20
The factory UCAs should fit fine with 33” tires.
Tire size isn't the issue for UCA's. It's the CV angles. Even if you aren't off roading there are potholes, speedbumps, and all other types of road hazards that can cause your suspension to max out on travel. Admittedly it isn't very likely to happen frequently. Just saying. However, if you can get a good alignment, you are probably good with stock. If you are off roading then after market UCA's are a must. Also, you may want to consider more offset than +1 due to airing down. Have fun.
the commuter kit is designed to be able to run factory UCA because it has an internal limiter that limits the droop to be within spec for OE UCA.
You can remove that limiter and go Carli UCA when you're ready.
If I wanted to run a 20x10 wheel, can any suggest the correct offset?
I want to run a 35/12.5/20 tire or worst case a 285/65/20.
Thanks
Thanks
-12mm and you'll have no problem with most in terms of uca clearance, just need to trim your fender liner which is not a big deal at all.
if you go off pavement a go hard, trim the pinch weld is highly recommended for maximum clearance.
