- Jul 25, 2020
Being 1/2 qt over filled isn't going to hurt a thing. No need to drain any out. You will easily burn that off before the next oil change.️️️AMMENDMENT️️️
I got to thinking, maybe the oil hadn't completely flowed through when I checked after my test run to warm up oil to 210° and then recheck to Pacbrake fittings for leaks!!
Sure enough, even though 8qts showed right to the top hole (Full) on the dipstick(two days apart), it now shows overfull by about a half quart a week later (good thing I barely used the truck since)..I'll repost when I measure exactly how much drains off to Full mark. (hallelujah for the Fumoto valve) WTF
