Mystery shhh-shhh-shh rubbing noise
boldram
2019, 1500 42,000 miles. No mechanical issues, top shape. Lately when turning right, only right, I hear a fainted shh-shh-shh rubbing noise, turning 10-15 mph. Checked tire well, mud flaps, limiters etc. No indication of anything rubbing against each other. Front end and steering in excellent condition, car drives fine. Drives me nuts. Sound does not bother me but what causes it.
Wheel bearings start with a little bit of rubbing sound. 500 miles later they glow red to let you know that they are bad 😕
My first guess would be worn brake pads or warped brake rotor. At 42,000 miles if you do a lot of start and stop driving you are probably due for brake service.
Why would it be only at a very slow speed turn and turning right only. Sound is hardly audible. Once vehicle goes straight or left above 15 mph, sound disappears. Most people wont even notice any sound unless you drive this car everyday.
brakes at above 50%, rotors are baby bud.
I thought wheel bearings noise is constant and gets louder with speed. In my case it is fainted and only when i turn right at 10-15 miles ph., otherwise there is no noise at all.
Sounds like brakes. May have a caliper sticking a bit, or maybe a pad has picked up a bit of road grit or a rust flake.
Not sure what "baby bud" means, but unless you have used a dial indicator to measure runout you can't really tell if your rotors are good.
If you do much city driving at all, it's very likely you will need your brake rotors turned at 42000 miles even if your brake pads are still good.
As your brakes heat, subsequent application of the brakes will leave tiny patches of brake material on the rotors and these patches will eventually grow in size until they are tall enough to lightly rub on the brake pads under certain conditions. Instead of being evenly distributed around the rotor, they are like a wave around the rotor which results in the on-off "shh-shh-shh" sound. If you have significantly overheated your brakes it's possible the rotor is warped.
It's been my experience the symptoms you describe while turning are atypical of a brake rotor issue causing the pad to intermittently rub. Could be a wheel bearing, but that would be my second choice.
Either way it's probably not going to get better. If the rotors gets worse you will begin to feel pulsing in the steering wheel when braking. If the bearing gets worse you may start hearing a loud screech then potentially see your wheel & tire pass you when driving down the highway.
I see your point. I have experienced rotor noise on other vehicles and this is more of rubber/plastic low pitch fainted intermittent noise only when turning right at 10-15 mph almost bringing steering to the turning limit, NOT engaging brakes. I found some Dodge technical bulletins describing this issue. For now i will monitor. Dealerships not willing to do anything for now.
sounds like a brake pad just dragging a little. Maybe they are junked up and just not floating as they did at one point. Not really an issue. I lived in the snowball for sometime and would pull brakes, pins etc apart every two years or so just to Clean everything up even when the pads were still good. Jack I up and hand spin the wheels and maybe you find something.
Disk brakes tend to be noisy out of the gate, compared to drums. It's all out in the open, not contained. Last year I put new brakes all around on my Mazda and used metallic pads, sort of on a whim but also for maximum whoa. It'll stop on a dime, but they are noisy. It does like you describe the first thing in the morning and for a couple of turns until it warms up and settles in. And I know it's all lubed and working the way it's supposed to, because I did it myself. I probably won't do full metallics again now that I know, but I'm okay with it. It's a work car, not a pillow.
There’s a TSB for the power steering. Mine made a noice before they flashed the BCM
